Upon starting my car this morning my nav screen started to come up but then turned completely black and all the center console buttons and lights also went black. Everything else works. None of the buttons on the center stack work except the mag ride control and hazards. The nav screen will not go back down. I have tried pulling the positive battery cable off for 15 mins and still nothing however once I put the positive cable back on the screen now illuminates black but stays blank and still none of the lights or buttons on the center stack works. I have tightened the ground bolt in the trunk in the center of the fuse panel. I looked under the drive side seat for any disconnected connectors and found nothing. I will check the fuses and pull the center console trim to look for any loose connections. Has anyone else had similar issues and ideas on what happened or what to look for? I have seen a couple of posts but no solutions.
2012 CTS-V coupe
2012 CTS-V coupe
