Are the clips pictured an adapter or do you have to cut off your factory connectors and wire these in? ThanksD3PE PROSPEED 1000cc Injectors for the LSA
The D3 PROSPEED 1000 is a Bosch based Ev14 High Impedance fuel injector, utilizing the latest in fuel injector technology. They come in sets that are matched within 1% static (I.E. Full Flow) and 2% dynamically (I.E. being pulsed). This matching process provides great cylinder to cylinder consistency. The matching process combined with the fast response and linearity of this injector produces amazing idle qualities, excellent drivability, and smoothness not found in other injectors of this size. This is a factory injector and is not modified and matched specifically for D3 for the GM LS series engines.
We provide injector deadtimes and flow ratings which makes calibrating your fuel maps easier. The D3 PROSPEED 1000’s will operate with up to 7bar of fuel pressure differential. It has a USCAR/EV6 connector, but will come plug and play connectors for your application. They will be provided with hats and adaptors to fit your specific application. The D3 PROSPEED 1000 is compatible with all fuels including gasoline, ethanol, and methanol.
*Price is $749.99 for a set of 8 shipped in the lower 48!
*Dealer inquiry's welcome!
