How can I tell if they are toast? I have the DS axle assembly out but PS is fighting me at the moment.
Sent from my SM-S906U using Tapatalk
Thanks but I meant inspecting them on the bench. I can remove the bolts but what am I looking for to confirm?When the CV joints went out in my 2006 GTO I knew they were bad because they made loud grinding and creaking sounds when I would make turns on flat or uneven surfaces. I is very noticeable! They had an IRS just like the V so I would assume that's one sign you can check for.
They were definitely making noises (awful popping/crunching) when turning left or right.... but silent going straight. No boot damage or grease leaking at all. I hate throwing parts at a problem but all signs point to the cv joints. I wanted to visually inspect them before ordering a new pair and I guess I have to remove the boot to confirm.No signs of boot damage or grease leakage, and they weren't making noises before you removed them, they're probably just fine. There are bearing surfaces that can be inspected, but you'll have to disassemble the knuckle and clean off all the grease to see. If you don't want to go all the way, then just test them for lash. Clamp one end and see if you can rotate the other end a little. If you can the CV is probably wearing out. There's probably a spec for how much lash is allowed, but I have no idea what it might be.
Well it's not like the axles don't have wear and need to be changed, any way. I just expect that the noise you are after will likely remain.Interesting. I've changed the diff fluid at 58k and again at 102k. Both changes I used M1 LS 75w-90 which already friction modifier in it.
I've already removed the axles in anticipation of replacing them. I guess I'll find out what the issue is on Wednesday night.
Which as I recall from the last time I used any, smells like I imagine rotting whale sperm would smell. It's nasty smelling shit. Gag a maggot nasty.the GM friction modifier.
