Crank NO START MAP SENSORS
1349 Views 5 Replies 6 Participants Last post by  04chase
Hello everyone! So let me just start from the beginning here lol - recently a week ago I noticed a noise coming from my rear, I checked it out and saw my axel was leaking. So me and my buddy replaced my axel seal gasket, but in turn popped the DIFF TEMP SENSOR out, and we started the car up without it plugged in. It put the car into limp mode and threw a CEL. We drove it down the road quick and it made 0 boost. We parked it and plugged the DIFF TEMP SENSOR back in, and still had a MAP CEL. After seeing that we hadn’t noticed there was 3 ACDELCO MAP sensors (2 black and 1 red) so we had replaced 1 of the 3 with a BOSCH MAP sensor, and I believe the place sent me the wrong part number as well but not 100% sure. After we plugged the BOSCH sensor in, it fired up and we drove it down the road, still 0 boost. So we parked it and put the old sensor back on and then all of a sudden it wouldn’t start. Crank no start. We ordered 3 ACDELCO MAP sensors (2 black and 1 red) and replaced those yesterday. Still at a crank no start. We checked for spark and we are getting spark, but upon cracking the fuel rail, nothing dripped out even knowing I have a full tank of 93 in it. At the moment I’m at a complete loss as I don’t know why I wasn’t making boost, and now I can’t even get it to start. So as a recap it started with no BOOST PSI, now it won’t start and potentially still doesn’t get BOOST PSI. Maybe vacuum leak for BOOST? Idk? Not sure where to look for a boost leak, but can’t even get it started to check now:( . Not too sure what’s going on but I will Provide a mods list below so you all know general what’s been done to it. TIA
  • Full fore fuel system reg pump and rails
  • Tuned for E85 & 93
  • D&H motorsports crank case breather and catch can
  • Vader heat exchanger
  • Vmp under hood ice tank
  • ID 1300 injectors
  • Custom grind cam
  • Ported Heads
  • Ported Blower
  • 2” stainless works headers
  • Straight piped into Borla Mufflers
  • Linginfeltzer Upper pulley
  • ATI lower pulley
  • 102 mm throttle body
  • ID 1300 injectors
  • Custom grind cam
  • Ported Heads
  • Ported Blower
  • ATI lower pulley
2010 Sedan V 750 RWHP
1 - 6 of 6 Posts
First things first. Get it to start!
When you turn the ignition switch forward does the fuel pump prime? You should also put a mechanical gauge on the fuel rail to see what pressure if any you have there. If it cranks and you have spark but you said only a drip of fuel come out to me points to the fueling issue for the no start. Check all your fuses to make sure you didn't pop one trying to address the other issues you are having.
Make sure you didn't break a connection to one/all of the sensor connectors.
I had a map sensor (the red one specifically) that would fail when the car got warm and it would crank/no start until the car cooled down; took me a while to sort that out as it never threw a code, But I would verify that you plugged the two on the lid in correctly, it is possible to plug them in backwards (the plugs are the same for both sensors)
If you have the full FORE! system, there is likely a fuel pressure gauge on the regulator. Does it jump up when you turn the key on, even momentarily?
if you have a flex/dsx kit with the map sensor harness id be checking there , i have had multiple 3 bars go bad and do the same as well. make sure they are the correct location and check wiring.
next check fuel pump relays and fuses , could have lost your hobbs switch(turns on additional pumps in boost)
1 - 6 of 6 Posts
