California just needs to admit to itself that Everything causes cancer- including living in California.Don't forget the Prop 65 warning.
No cracks, stock suspension, stock wheels. I am going to replace the cradle later this year with chromoly.Just out of curiosity - if you've noticed your subframe was cracked, are you running the stock suspension still, or have you made mods like, for instance, Eibach springs, bigger wheels/tires, sway bar upgrade, coil overs, etc...?
Just one man's opinion: you are fooling yourself.
I'm not saying you are doomed or that it will progress rapidly (maybe not at all) but I believe is a crack.
Keep an eye on it and take pics each time.
Just a matter of time before small turns into big. Keep an eye on the weld repair, unless properly annealed there is a good chance it will crack again.You were 100% correct MrSurly! Here I am 7 months later in the shop getting the upper and lower control arms and struts replaced. Now I'm waiting for the fabricator to come and weld the frame tomorrow. This is some scary stuff!
View attachment 164191 View attachment 164192
Yeah, that will probably never happen at this late stage. How are the welds holding up under the conditions you drive?This should be a recall. I welded mine last year…
I'm having some difficulty finding a welder in Ft. Worth, TX. My original guy is booked till late February and the car is still at the alignment shop.This should be a recall. I welded mine last year…
Excellent news!I drive mine like I stole it. New brakes and tires every year. No cracks have come back yet. On the way to a new set of Pirelli tires…
not to beat you up but no way would I have left the shop with that, that was dangerousYeah, I'm mad as hell. He shouldn't have let that guy near my vehicle. He told me he had welded for him before and did good work. This shop specializes in lifted jeeps and trucks but do alignments and other builds including custom roll cages. I told them that you can clearly see the crack after they dressed it and they should have stopped there. Now the shop is looking for a subframe and I'm looking for another car as this is my daily and I don't have a backup. Can anyone verify the proper part number according to my VIN? (1G6DP8E39C0115024) It's a 3.6L RWD. I can't help to think that this is going to end up in court. Thanks for all the input.
