It would be worth your time to take the pad off and clean it with electrical cleaner. Very simple to do and cleared my same problem. If you go on youtube there are videos, but most pertain to the corvette however it is the same concept.
Tried this and so far it looks like it may have worked.It would be worth your time to take the pad off and clean it with electrical cleaner. Very simple to do and cleared my same problem. If you go on youtube there are videos, but most pertain to the corvette however it is the same concept.
Awesome! I did end up replacing my door latch also later down the line just like PGA2B said, but I cant remember if it was because of this issue or another. Hope it keeps working for you, but if you do end up needing to replace the door latch keep in mind there are two different latches depending on if you have the theft deterrent security system on your car or not. Very minor differences between the two...Tried this and so far it looks like it may have worked.
Thank you.
I’ve had the door latch replaced years ago. That was because the radio would not turn off after opening the door. That issue just started acting up again and tried the solution of lubricating the latch with silicone spray and working it in. That addressed that issue.Awesome! I did end up replacing my door latch also later down the line just like PGA2B said, but I cant remember if it was because of this issue or another. Hope it keeps working for you, but if you do end up needing to replace the door latch keep in mind there are two different latches depending on if you have the theft deterrent security system on your car or not. Very minor differences between the two...
Mine has done this once or twice, good to know it might be a simple fix.I’ve had the door latch replaced years ago. That was because the radio would not turn off after opening the door. That issue just started acting up again and tried the solution of lubricating the latch with silicone spray and working it in. That addressed that issue.
Just spraying the mechanism isn’t enough. You need to work the latch with your finger back and forth and then spray a bit more.Mine has done this once or twice, good to know it might be a simple fix.
