Coolant air bleed block off
1381 Views 16 Replies 8 Participants Last post by  cav454
Good afternoon,
My engine upgrade is coming along really well. I was wondering if anyone had the part number to an engine coolant bleed block off?
thanks in advance
1 - 17 of 17 Posts
Are you talking about a block off for the steam ports?
Yes sir
Allowing the steam to leave the head I would say is preferred once you start mods. I know you can purchase a cheap crossover (OEM style) and plumb it to your overflow return on the DS fender. Keeping the heat from building up in those back cylinders is a big plus (since they have been noted to go lean), and your tuner will like you for it. I used this for mine.
Good Luck, Jeff
Good Luck, Jeff
The heads I bought have them on both ends. I want to block off the rear. Would you suggest using both the front and rear?
So the front you would use the OEM set up or even purchase and aftermarket steam vent kit (for all 4), but yes, I would not put Any plugs in the heads, I would have all 4 ports open and vented to the overflow tank. There are a lot of articles on how steam trapped in the top of the heads (on LS) can cause premature detonation, and or hot pockets above the back cylinders which is no good.
Hope I'm helping.
Good Luck, Jeff
May I recommend the following:
4 corner steam vent kit
Reactions: 2
Thank you very much for the replies
That will never fit once the blower goes on.
i would look into the Motion Raceworks steam port kit for lsa. I have it its a very nice kit.
This is my issue. Everything is back on the car and I don’t want to take it apart.
I bought the rear vent kit from Random over a year ago at least....still sitting in the garage cabinet. I think whatever residue was on it should be inactive by now.
I was merely illustrating the 4 corner kit as a possible resolution, not necessarily the specific kit I went with. Definitely look at Motion's LSA kit.
Sir the kit you showed is certainly the kit I would have gone with.
In my case, I'm going twin turbo with Holley sniper intake... So it fits underneath without issue.
I used the Nitrous outlet steam vent kit, fits well and looks nice.
LSX Water Vapor Bleed Crossover Kit For Retro Fit LSA Blower Applications
I use the same kit. It’s a prick to install with blower on.
1 - 17 of 17 Posts
