1 - 9 of 9 Posts
Picked this up earlier this year to turn into a drift car. Car had blown engine and popped up locally for $600. Began the tear down pulled the engine, all interior, factory harness as well as swapping put to Megan coilovers (still divorced set up). Originally I was going to put a 4.8 in it I pulled from a prior project car. I ended up breaking off the starter portion of the block and scraping the 4.8 idea. After looking at the prices of 5.3 and 6.0 engines I decided to order a c5 ls1.
Sent from my SM-G991U using Tapatalk
I like the painted intake. Make Cadillacs Great Again!
Discussion Starter · #4 ·
Working on this today, pulling the bad 4.8 out, and prepping the c5 engine this week. Need to get the oil pans swapped out as the vett pan won't work. Probably will drop it in next weekend and start building a Trans mount. After will need to figure out a shifter solution as I'm using a camaro t56.
Made a little progress today, ls1 is in but have a couple clearance issues to figure out (f body pan) touches the subframe. Also the alt doesn't currently clear the strut tower.
Your neighbors hate you, don't they?
Discussion Starter · #9 · (Edited)
To answer all in one, no my neighbors are all pretty cool about it (built many cars in this drive way over the years). Have no where else currently to build it till I hear back about a house I'm looking at. Car will not get boost my actual v is looking like it'll get a turbo or some spray tho.
1 - 9 of 9 Posts
