Have you ruled out the motor mounts themselves?
Yes. I replaced both motor and trans mounts.Have you ruled out the motor mounts themselves?
Thanks for the update, it's always nice to read a follow up resolution. Sorry it's not better news, but at least you found the issue prior to engine grenade!Just posting an update. I found the issue. My number 8 piston cracked. I finally had enough of looking and removed the heads. Big crack in no8. Going to do a full rebuild now. With new pistons new cam sending the heads off to Frankenstein. I’ll start a build thread once I get the block back from the machine shop. Just wanted to put the info out there in case someone else has the same issue.
