1 - 20 of 36 Posts
Cars been running great, including yesterday - parked overnight, started it up this morning and 100’ down my driveway (no throttle) it throws a code and goes into limp mode. Pulled codes and it looks like a TB issue, but how would the mechanics have changed?
153251
Discussion Starter · #8 ·
And this code just randomly popped up? If so, try and do the relearn method, reading the code it does say "idle not learned".... Can't hurt to try it.
Yup - I’ll Google how to relearn a TB but why would it suddenly lose its “learn”?
Also check intake connection. Might be sucking unmetered air.
Will look into it
That's weird, any battery issues lately?
None - only real change from yesterday to today was plugging in an Autometer Dashcommand but it was in last night when I drove home and car was fine. Left it in OBDII overnight but can’t imagine why that’s change anything
I've had that code before and unplugged it and reconnected it and it was fine afterwards. Not sure what caused it but it hasn't happened again.
Discussion Starter · #11 ·
Any chance this gap from the rubber hose to the metal fitting could be throwing the code?
I checked the TB and it isn’t touching anything and has a clean rotation
153254
153255
153256
Discussion Starter · #12 ·
Unplug it and retest.
Unplugged the battery, pulled all the connections, checked it, plugged everything back in, and reconnected battery. Turned to on, code still there. Turned it off, opened the door then cleared the code and still there. Cleared again, this time I start the engine right away, idles great for about 10-15 seconds then turns to garbage and throws the same code.
i got that TB code when i swapped to a larger TB on mine as far as i know just have to relearn it as something must have happened for it to loose the vehicle off memory maby ? try the idle relearn procedure, with mine i was only testing without the engine so i couldnt run it to see if the relearn was the fix
Definitely do the relearn first.. could be a bad throttle body or like gts said a bad connection making it forget the adaptation somewhere. That pushlok has nothing to do with it, but if it makes you feel better and you have enough hose, cut it behind the barbs and slit the hose to get it off the fitting. Use wd40 or silicone spray to get the hose to seat all the way.
2013 CTS-V Coupe 6MT Silver/Black
I got that same code maybe a month after installing a brand new ported LSA TB. I read about all the common issues to look for but didn't know which one might've been my issue. So I treated them all. I took the TB out, cleaned it, cleaned the connectors, cleaned the MAF sensor, and did a throttle Relearn. Hasn't come back since then. I know 4000 miles w/o issue is a long time. But it wasn't really a huge burden to do all those things to try to clear it. And it worked. And when I had reached out to Tony Mamo when it 1st coded he had verified that it's pretty common and usually just a simple relearn will clear it out. But I did the checklist anyways just to be sure
TB hasn't been touched since install 4000+ miles ago
What kind of TB is it? $200 ebay? or Tony Mamo? I had the ebay TB leave me on the side of the road and require flatbed to get the car home (on f*ckin date night!). So it can take a shit when driving or 2min after start up. I just went to the new 103 from Tony Mamo, very nice unit and actually makes the car feel different under acceleration. Good luck.
Discussion Starter · #19 ·
The relearn is just letting it idle for 3min in park, turn off for a minute then idle for 3 min in park again, right? After that drive over 45mph with some decels then let idle in park for 5 min.
Discussion Starter · #20 ·
it Is an eBay TB. If I can’t get this figured out, may need a NW103
1 - 20 of 36 Posts
