1 - 3 of 3 Posts
As the title states; the Car stops firing the injectors when it gets warm.
A while ago (late last year) it did this after a spirited highway pull, had it towed to a shop, and it started working again before they could diagnose it. Never did it again until recently.
Now, as soon as it gets to any oil temp over 150, it stops firing the injectors, and shuts off. The injectors still have 12V when this happens.
I have checked all of the engine grounds, ground under the intake, Replaced the ECM, Disabled VATS to rule out the key fob, and still have the issue, so I'm at a loss. Anyone have any ideas or ran into anything similar?
Discussion Starter #2
Welp, I solved this, MAP sensor was reading whacky when it got hot, replaced it and all seems well.
1 - 3 of 3 Posts
