Would really appreciate some feedback, I have been searching the forum and reading threads for a few days now and can't find a situation quite like mine.
About a month ago, had an overheat situation idling in a drive thru line. Found out the engine cooling fans were not coming on. I replaced the fan assembly and no further issues.
Then driving about 2 weeks ago, the ground cable on the back of the alternator broke off from the connector. I got the service battery charging system warning, car started disabling everything but I made it home. I fixed the connection and drove the car a few times afterwards with no problems. I have been watching the battery voltage ever since and alternator recharges the battery to around 14 volts after cranking. So I thought everything was fine.
Got in the car last weekend after it sat for a week, still have the DIC on battery voltage. I watch it after cranking and battery recharges back to 14 volts. After driving for about 5 minutes the car dies. Electronics are still working, AC is still on and radio. I coast into a parking lot and stop the car. Try to restart and starter turned over slightly but no crank. I attempt to jump the car with cables but it will not crank. Now I just get the one click like the starter is bad. I pulled the battery and took it to a part store, they tested it and said it was fine.
I got the car towed home. I removed air intake, jacked the car up and started checking all ground I can find, looking for any loose connections and found nothing. Ground on back of alternator still good. After reading here, I decided to replace the crankshaft position sensor and starter while I was there. Been having the hard crank issue when hot for a while, maybe a new starter will help.
After replacing the starter and sensor, car still will not start and I get the one click on the starter but no crank. All accessories come on and are working.
Not sure what to try next. The way it died on me, I don't know what it can be.
Any suggestions?
Any suggestions?
