1 - 20 of 20 Posts
Chevrolet Cadillac CTS-V 2009-15 Heat Exchanger for Supercharger
The C&R CTS-V heat exchanger mounts in the stock location, using factory hoses and clamps. Using 42mm PWR purpose-built core it will keep the intake air temps (IAT’S) lower. Compressing air will increase the air temperature. Cooling it allows for a more dense charge. You can feel the extra power. This is a must-have part for increased boost levels and in hot climates. This kit includes a Brown & Miller hose and bleeder allowing you to service the cooling system without removing the front end. It simply tucks back under the core support between the radiator and core support top plastic cover.
  • No modifications required
  • Uses factory hoses and clamps
  • Uses factory mounting hardware
  • Includes Brown and Miller bleed hose and fitting
  • Must have part for increased boost or hot climates
  • Easy upgrade for any 2009-15 CTS-V
It mounts in front of the radiator. It is a separate cooling loop not part of the radiator for the supercharger. You remove the factory HX.
Reactions: rmcbeezen
One more thing: the inlet and outlet are in the stock locations on the C & R to facilitate the use of the factory hose arrangement. The Track Attack has a downward facing connection on the driver's side, which requires some modification to the hose on that side. It is a tight fit in there because of the much larger tank size than the stock unit.
I have the C&R HX, it is virtually plug-n-play, you can see it here right after I installed it (I painted it semi-gloss black). It's a very nice piece.
Motor vehicle Hood Automotive tire Automotive design Vehicle
that lift system looks awesome! I’ve never seen that before.
That's the BendPak 7,000lb rolling bridge jack, I wouldn't have a 4 post lift without one!
Oh it's definitely handy when you have to R&R your wheels! ;) :ROFLMAO:
Tire Wheel Vehicle Automotive tire Vehicle brake
So that’s what you do with all your downtime during winter lol. Sick edit.
Pretty much LOL... thanks!
Didn't mean to hijack the thread... here are a couple of additional pics of the C&R HX, you can see the difference between the stock HX and the C&R in the bottom photo, pretty dramatic!
Rectangle Wood Floor Grille Home appliance
Wood Rectangle Gas Composite material Hardwood
It was comparable in cost and dimensions as the Weapon X version when I got mine, but that was a few years ago.
Reactions: Omgctsv and jcs003
1 - 20 of 20 Posts
