1 - 5 of 5 Posts
Anyone have any helpful tips on the best way to fix it? Not very important issue but would like to do it right. I was gonna just drill it out and put a screw in it but figured I would ask.
I would grind it smooth, drill it out and insert a rivnut. then make or buy a stud .
I grinded it then threaded a screw in. Thanks for the help though.
At my shop we use a stud welder from prospot to replace those when we change sheet metal parts on European cars. It places a very small weld on the stud and works great. At home a nutsert would probably be the fastest, but it looks like you figured it out.
I'd personally drop the upper A arm knuckle, grind it out and put a through bolt in it.
But it's also just holding the AC line and not exactly critical.
1 - 5 of 5 Posts
