1 - 5 of 5 Posts
*pedal. You're not selling something.
+1 for bleeding the system.
if you opened the lines you get air bubbles. Try a scanner that lets you bleed the ABS unit. Unit is far up on the passenger side. I use DOT 3 Ford High Performance Brake Fluid. The ABS unit likes the stuff. stay away from synthetic fluid as it messes with the ABS.
1 - 5 of 5 Posts
