Since you have HP Tuners you should be able to dial in your fueling. Of course figure out where all that oil is coming from first. What brand of catch can and how do you have it routed?
A compression test will not tell you if the rings are controllingI bet I had half a quart in there!! Wtf? Time to reevaluate my catch can.
Oil in the combustion chamber greatly lowers octane leveli believe the oil ignites at a much higher temp then petrol so it dosnt get too calculated in the fueling by the 02's, its more so the oil only starts to burn which is why it stays mostly a sludge and builds up on everything, worth keeping an eye on fueling just encase it does a little tho as prob not sure what it was like before
I'm with @07GTS on the valve stem seals. 130k on the engine with 150s psi across all cylinders with even compression is respectable. make sure if you replace the seals be aware that the intake and exhaust valves use different valve seal part numbers. That's a lot of oily plug buildup for only 1500 miles with or without a catch can. At least they are all the same.Ok here are the compression test results:
#1 150psi took to turns to get there
The rest took 3 turns to get to the max pressure:
#2 152psi
#3 147psi
#4 148psi
#5 149psi
#6 148psi
#7 150psi
#8 148psi
No evidence of leaking rings, or worn valve stems.
I decided not to do a wet test since the dry was consistent.
Try @07GTS of this forum.I need to see if someone with HPT experience can look at my tune on here.
Attached is an image from one of my cylinders prior to valve seal replacement.I'm with @07GTS on the valve stem seals. 130k on the engine with 150s psi across all cylinders with even compression is respectable. make sure if you replace the seals be aware that the intake and exhaust valves use different valve seal part numbers. That's a lot of oily plug buildup for only 1500 miles with or without a catch can. At least they are all the same.
Not sure I understand?@kittyboy How'd you get your fingers in there? And looks like you lost part of your index finger.
Your picture looks like fingers to me, minus part of the first one. So how did you get your fingers in the cylinder to take a picture.Not sure I understand?
CAI doesn't provide vacuum. It provides fresh air that has been filtered and metered by the MAF to replace the air and oil fumes pulled through the PCV or catch can.The CAI intake is just to provide vacuum for the can (can out).
Sounds like it was sucking oil from the passenger valve cover.
At least you found it before it broke something.
