I'm also curious to see how it would look on white...Want to do mine so bad! Will look sick on my white wagon!
do you have a pic straight up on the car?heres the new look
Didn't want to commit to matte/satin finish. Will be redoing it in a gloss finishI don't understand why use plastidip unless you seriously plan on take it all apart again to peel it off... if you want a nice smooth satin paint color use bumper trim paint. It's durable and has a nice satin. Sprays on very smooth and thin not like plastidip
This is how mine came out![]()
Copying Mavickreations![]()
I am sorta local to you and I have done a few sets. If you want some help and want to make a trip up to Seattle, We can do it in a few hours.I want to do this so bad! Thanks for taking the time to do such a great write-up!
Doc,I did it!!!!
1) the instructions in this post are spot on, I will add some things though
2) this is totally do-able
Additions: buy two cans of paint, one can primer. 215 degrees is good, didn't need the card board, start prying with a dog bone on the uppermost/outermost corner of each light (it's the pointiest corner). you must attack this when it comes out of the oven, don't be afraid to put it back in for 5 min and then re-engage. Also, make sure you clean the inside of your lenses before re-assembly. I didn't and there are some dust particles. Hardly noticeable but I have OCD. Make sure you have one tube of silicon per head light. I really like the bumper paint, it's mildly textured which makes it look oem.
I did, I primer coated everything and then painted with bumper paint. I really like the look of it, it's mildly textured which has an oem look to it.Doc,
Did you paint the inner chrome projector bezel as well? What paint did you use?
Thanks
A
Can you tell me who does this and if you have a contact number? Thanks.If you're in charlotte nc, there's a place that does this for 200 and 350 for demon eyes and Bluetooth controlled halo rings
Sent from my SM-N920T using Tapatalk
7049755589 friscia's customsCan you tell me who does this and if you have a contact number? Thanks.
You buying new or used?That stinks! Those are pretty big cracks and will likely get worse, or a piece fall off, when opening them.
No lenses available by themselves. From reading through the thread others are buying normal aftermarket CTS lights for cheap and using those lenses. They fit and very similar.
I'm doing mine soon, but have the spider cracks on the front lens itself. Mainly on one side. Buying the CTS lights and replacing.
