1 - 12 of 12 Posts
Is there a preferred manufacturer/supplier of TPMS?
New wheels are about done and figured I'd get new sensors for them, or am I better off just letting the tire shop sell 2 to me?
Don't know if there's a preferred supplier/manufacturer but you might contact Jon at bestwheeldeals as he sells them. I'm getting new wheels soon as well and will go with black stem sensors since my new wheels will be black with a tinted face.
The sensors are 315mhz and I would assume that your tire shop could supply them as well but you may pay more for them. Other option is to reuse your existing sensors.
Which wheels did you go with? I went with a set of VS-02's from Jon with 19x11.5 rears.
I found some coupe wheels that are about finished at Weldcraft being widened to 11' so 325s will be tucked in.
I've sold my existing coupes with tires to a sedan locally.
So I have to get 2 sensors.
TBSS, Corvette FRC, RS 3
I've had good luck with a tpms site that sells them "direct" if you catch my meaning. All OE parts and excellent customer service.
Some tire shops are dicks about installing and programming customer supplied sensors. They also may not be able to program them depending what tool they're using, some of the tools require you to use only their sensors.
There are quite a few aftermarket suppliers of TMPS sensors that will work with GM. And they can be quite a bit cheaper than the OEM sensor. But some have tricky programming requirements so you have to be sure you know what you're buying. I haven't done this with my V, but I did with my 97 Corvette, and then when turned on TPMS for my 02 Z06 (which I was able to do by borrowing the Tech-II scanner from a friend who managed a Chevy service department), I used some 3rd party sensors. Cost was about 1/3rd and they worked fine. But I'll be damned if I can remember the manufacturer...
Same here. The Huf's tend to work pretty well with GM.
Standard motor products makes sensors that only need factory relearn procedure from owners manual. About 35 a piece and cool if you have a tire machine and no programmer. Denso makes the oe sensors, and oro tek makes sensors also capable of being flashed by a tech2 about 5 bucks cheaper, and dorman makes oe programmable sensors as well, but they're around 40. Pretty much everyone else wants you to own their specific tpms programmer. My napa rep always tries to push the autel tpms sensors on me, they give you the programmer for free if you buy a couple sets of sensors.
I kinda think it's bullshit that they do that.
Discussion Starter · #9 ·
This is a pretty good tire shop and did my brakes and reprogramed so they read correctly.
I'm going to have them do the new axles so they shouldn't be too dickish about the sensors.
V Coupe Pedal car
Same dilemma here. A pair of MTs ordered thru local Discount Tire; a set of wheels from other sources. I will likely buy PS4S tires (from DT) for the fronts.
How much does Discount Tire charge for the TPMS units?
Should I get some ahead of time or are they reasonable at DT?
Are the ones that DT offers the same as OEM, meaning re-learnable without a tool for future use?
Reactions: Blades1_99
I got the VDO black stems from Rock Auto. They were a good price. Use factory relearn procedures.
1 - 12 of 12 Posts
