1 - 1 of 1 Posts
It looks like I'll have to bend my oil squirters to clear the JE piston pin webbing so I'm looking for a little advice from those that have done this. Just eyeballing, it looks like they'll be pretty close to the center of the pin webbing. I'm thinking I'd like to move them toward the rod side but won't know for sure if this causes a different problem until I get further along. The stroke is 3.825" so I don't believe the piston skirt will extend much if any beyond the bottom of the cylinder.
Are they easy enough to bend that you just bend them by hand?
How much can you bend them side to side?
How much clearance do they need from the webbing and/or rod?
1 - 1 of 1 Posts
