What would be the advantage of the 100mm pulley? Reduce belt slippage if any presents itself I assume?You should be able to use stock size belt with 2.75 upper, if not, maybe throw on 100mm idler pulley and that should help.
Thanks for clarifying! I will do that!Reduce slippage, and more belt wrap (your case).
Like I said, I would try stock belt first.
