Well, if you want to wait, I'll probably be willing to print some pods for others. I'm not going with the vent mount, it'll be "integrated" with the dash. And I print "SLA", not "FDM". I prototype with a FDM printer because it's faster and cheaper. Final prints are done with SLA. SLA prints look like they came out of a mold.
I made this with the SLA printer (the letters are laser cut from colored acrylic, not 3D printed. I also have a laser cutter, and a 4-axis benchtop CNC).
Printed these for my Nephew.
I'm certainly willing to wait... this build has established that as fact.
Are you creating a single or dual gauge mount?
I know that I will be installing a wideband gauge (AEM?)
and also an Aeroforce both are new.
It
looks like I can sub the Banks fior the Aeroforce.... is that accurate?
Any reason to 1. NOT do this or
2. to retain the Aeroforce along with a Banks???
I wish the Banks could read the added wideband but I don't think there's any support from Banks on this.
I did talk with their sales folks and learned some things about the gauges;
There are two connections in the back of the gauge (either Super or Monster)
Both connections are 6-pin Molex style; Edit: One is 4-pin (OBDII) other is 6-pin
Their OBDII uses the 4-pin.
The 4 or 5channel add-on analog modules they sell require their B-Bus cable to connect...it plugs into the other molex port
They offer analog module sensors for various functions, but not for AFR
They DO offer an analog pigtail that I THINK could be used to read the wideband's voltage signal and then display the voltage in the gauge
However, their analog adapter plus the pigtail plus the B-Bus cable would approach another 400bux.
SO,,,,I guess I'll still be using the AEM(!)
