1 - 6 of 6 Posts
When I was replacing the adjustable toe rods, I noticed the bottom passenger side of the fuel tank was wet with what seemed like oil. Everything in the area of the fuel tank was completely dry, so I wiped it all off. After pulling in the garage, I looked again and it's wet with fuel. I was hoping this is something that is a known issue, like a cracked vapor line or something like that. I saw a post for cutting an access hole to the fuel pump, I just did that to a 4th gen SS Camaro with a Dremel and it went perfect, but there wasn't any leaking fuel for the sparks to light off, so a nibbler sounds like the next tool to go buy. I'd also hate to cut an access panel to the fuel pump if the leak is elsewhere...
Any ideas?
Thanks!
Contact Adam at alm and get his billet fuel hat and be done with it.
1 - 6 of 6 Posts
