id guess at the time u got back into it and started up the fuel sender may have been at fault (may be wearing out over time) these usually read lower when they start to play up, and then as u drove the reading slowly worked its way back to normal in which the moving vehicle now prob keeps the reading out of the faulty spot or its not there long enough for the gauge to read it after dampening, if u always keep a full tank then it will wear out the full level first, if u use the tank each time then it can last longer as it slowly wears out the full span over time not just a single spot, we see that sometimes where people use 1/4 tank and fill up each time and the sender wears out the top 1/4 and the bottom 3/4 is brand new still,
if it becomes common maby log it on hpt will be a live reading before u start it up and see what it reads and if u have a full tank but its showing lower then shake the vehicle to get the fuel moving then if it changes and reads full u know sender is playing up
