Any way to manually control the muffler exhaust valves?
1363 Views 4 Replies 3 Participants Last post by  djdonte
Yes I know, you can change the modes. However, in my C6, the NPP exhaust was perfect. I had an aftermarket switch for it. All it really did was tap into the NPP fuse. Anyway, when activated, it stayed quiet-ish except cold start and heavy throttle. When the switch disabled NPP it was open all the time. This enabled me to keep it quiet and drone free when I wanted. It was vacuum actuated.
On our cars the muffler flaps are controlled by a motor but it seems to be opposite of NPP. In Tour mode, it stays loud and droney all the time until you give it alot of throttle, then it quiets up. Obviously sport and track it stays loud all the time. I have the SW axleback with flaps built in. I want to find a way to manually control those motors without running wires all the way to the motors themselves. I would need a wiring diagram of some type. I have a document titled CTS 2014-2017 service manual, but it seems to cover only the LSA sedans, not LT4, so there is no mention of the active exhaust. If anyone has access to the V3 service manual or any kind of wiring diagram that would be great. I'm sure the flap motors are controlled by one of the modules. I want to wire in a switch to enable to the valves to stay shut when commanded.
1 - 5 of 5 Posts
If the C6 is/ was anything like the LSA Camaro ZL1 w/ NPP, the flaps were open at idle, and close at low RPM. They would open under greater throttle position applied and/ or over 3500 RPM (I think). I pulled the fuse in my 2013 so the flaps are always open.
There was a separate fuse box in the trunk of the Camaro to pull the fuse.
I do not believe the CTS-V's operate in the same manner and therefore, unless you find a plug and play harness or do some "Mild-to-Wild" wired integration "exhaust controller", you might be out of luck.
Either way, good luck. Cheers!
Yes thats how the C6 worked. These cars are a bit more complicated it seems.
Looks complicated.
Yikes thats an understatement. Think I'm just gonna leave this one alone and live with the drone.
1 - 5 of 5 Posts
