Yes. It pumped oil.
I previously posted the attached charts, maybe they can be helpful. I do not have personal experience with the M355. I believe the stock LSA pump is a good option based on flow and pressure for most standard builds, definitely better than the 6665 my B15 came with.Has anyone here used the 10355hv oil pump? If so what were the results of the oil pressure?
I am aware the primary main oiling, but figured GM could have installed a better long block pump. Good choice, I was considering that same setup when I re-build at some point. But for now I am just going to be cognizant of the 6665 limitations at WOT. Guess the legacy LS1/LS6 6665 pump was an available and affordable option? It's the cavitation at higher rpm that concerns me most using the 6665.Your b15 has different oiling then a factory LSA and does need the volume. Melling actually makes a 10294 for aftermarket blocks with revised oiling and no piston squirters.
Yes, that was one prime reason I purchased the long block. However, it is better to build a purpose built if you hav the know-how skills, tools, and quite a bit more money!The b15 oils the mains first?
Yeah, if only a better pump I would have been a bit happier with the stock build and price. I did replace the dog bone when I installed the new clutch with an Improved Racing part. It's only 1mm more narrow, but if you do the math and logs, it helps...I would agree. some preach the B15 as the ultimate solution but it has its downfalls as well compared to a purpose built engine.
I was thinking about doing this but Its a pain to pull the trans and converterYeah, if only a better pump I would have been a bit happier with the stock build and price. I did replace the dog bone when I installed the new clutch ...
I would not recommend changing the part as a stand alone project, but if removing the transmission and clutch for any reason, it's a good time to do it. Replacement of the main seal and rear cover gasket as well.I was thinking about doing this but Its a pain to pull the trans and converter
I have this pump from Precision Industries (they blueprint the assy and debur and other things) in my rebuilt stock bottom end, with rods/mains turned .010/.010. As far as psi, a high volume pump may bump psi, but will not give you any specific raise in psi since it's moving volume of oil over the bearing surface which some builders like better. Bearing clearances will also play into psi, my bottom end rebuild was done by a machine shop that is a bunch of old-school racers that build to looser (higher) clearances and they knew I was using this specific pump. With that said, my hot psi is 20 on a 90*+ day and I'm running 60w Redline oil to help with that. I'm in the camp where volume is better than a ton of psi., when you look at minimum psi for this motor at idle 20 is actually ok and I think my max @ 6500 is 60ish..Has anyone here used the 10355hv oil pump? If so what were the results of the oil pressure?
.10 more clearance and the thicker oil and the pump is still only 20psi at idle?I have this pump from Precision Industries (they blueprint the assy and debur and other things) in my rebuilt stock bottom end, with rods/mains turned .010/.010. As far as psi, a high volume pump may bump psi, but will not give you any specific raise in psi since it's moving volume of oil over the bearing surface which some builders like better. Bearing clearances will also play into psi, my bottom end rebuild was done by a machine shop that is a bunch of old-school racers that build to looser (higher) clearances and they knew I was using this specific pump. With that said, my hot psi is 20 on a 90*+ day and I'm running 60w Redline oil to help with that. I'm in the camp where volume is better than a ton of psi., when you look at minimum psi for this motor at idle 20 is actually ok and I think my max @ 6500 is 60ish..
Good Luck
Jeff
yup, but I did say on a hot 90*+ day. but yes. however I am putting a lot of oil over the bearings. I've also noted my car has a lot less spark knock (mentioned from my tuner). When I spoke to the guy that owns Precision (who is a fluid engineer), he said that (the low spark knock) could be because I'm making a pillow of oil between the bearing and the crank. Hey all I know is it works and has been. Hope your build works well also.!.10 more clearance and the thicker oil and the pump is still only 20psi at idle?
My sister ock bottom end on normal oil is 22-25
It's a typo, no way .10, must mean .001".10 more clearance and the thicker oil and the pump is still only 20psi at idle?
