Another oil leak thread
755 Views 8 Replies 3 Participants Last post by  Ablackcts
2012 coupe, I noticed an oil leak (I thought was the rear main), then I slid under the car, noticed the oil filter was loose. I changed the oil, tightened the filter pretty snug this time, wiped it all down. A few days later, more oil. I do have a catch can but it only goes to the valley and S/C. My valve covers do not seem to be leaking. The leak appears to be coming from above the oil filter, on the drivers side of the engine. Anything specific I should look for? Is it possible that it’s coming from the PVC on the valve covers and spilling over?
1 - 9 of 9 Posts
The bracket the oil filter housing mounts to the block has a tendency to leak.....try righting the bracket or replace the gasket.
This one?
Or this one?
So I hear that these leak all the time and often do even with new gaskets. I’m planning on using RTV as well but are there any tips/ tricks before I get started?
I replaced the gasket, lapped both mating surfaces, also did an unexpected coolant flush.....
I still have a leak, its being blown back all over the transmission pan and exhaust. It does not look like a rear main. Maybe back of heads, or somewhere on the top of the block? Any ideas?
Oil pan gasket?
2
Just to add closure to this thread, the leak was actually unburned oil from the S/C due to a catch can issue:
Hood Automotive tire Motor vehicle Automotive design Bumper
Grille Hood Motor vehicle Automotive exterior Bumper
  • Wow
Reactions: 3
1 - 9 of 9 Posts
