1 - 6 of 6 Posts
Took to local stealership to try to zero up the camber. He said the front was off but didn't even bother with the rear since it was "green". I told him to try to zero it up. I didn't get "before" numbers on the printout so I have no way of knowing what the improvement was. Went back onto the rack to try to get more neutral camber on both front and rear, 30 min later brings it back and tells me he couldn't get it any lower and complained the exhaust was in the way to adjust (I have Corsa's which I'm pretty sure take up less room than OEM).
anyways is this as low of camber as I can go on eibachs or do I need to go somewhere else?
Font Handwriting Parallel Paper Symmetry
Not sure how I got quoted in a post I haven't commented on, but anyway. Just wanted to clear up that my car is still on stock springs.
Sent from my Pixel 3a using Tapatalk
Reactions: ThunderOne
1 - 6 of 6 Posts
