Are you affiliated with them? Know anything about them?
Most people want thatAnyone tried the new Kong dual brick lid?
KONG Gen 3 Billet Supercharger Lid (LSA/LS9)
The Kong Performance Gen 3 Dual Brick Billet Lid is the latest and greatest intercooled lid option on the market for the OEM LSA 1900, KONG LSA 2650, OEM LS9 2300, or KONG LS9 2650. It is a direct bolt on to any of these superchargers. The design resembles the LS9 placement of two single pass...kongperformance.com
Interestingly it comes with this disclaimer
***Supercharger whine. The billet design of the Kong Gen 3 Billet Supercharger Lid adds a significant amount of supercharger whine over the OEM LSA/LS9 style casted supercharger lids.
The going price for aftermarket lids with bricks it seems. Even OEM LS9 lids are $2k I think (used).Sexy, but $2800
Similar to what some call 'Ported TB's', this allThe going price for aftermarket lids with bricks it seems. Even OEM LS9 lids are $2k I think (used).
Jesse,Air temps. It's all about keeping air temps under ~140* F for the duration of a 1/4 mile pull, as the OEM calibration starts to pull timing. With E85 or meth it's certainly less of an issue, but then people start adding more pulley and `round we go.
So much like anything else, these $3k lids are really for people trying to squeeze every little bit out of their combo.
In my case, having the original Kong lid, it was just a more durable design than the GM product and able to withstand the higher boost pressure of the 2650 rotor pack, even if the IAT "gains" were minimal or the pressure delta slightly worse. With the GM lid and brick, I was crushing fins inward at around 17-18 psi.
Therein in lies the physics which many people fail to realize.Air temps. It's all about keeping air temps under ~140* F for the duration of a 1/4 mile pull, as the OEM calibration starts to pull timing. With E85 or meth it's certainly less of an issue, but then people start adding more pulley and `round we go.
Absolutely true!Most people want that
Nicely written my friend..Therein in lies the physics which many people fail to realize.
If everything else is constant, adding a more restrictive brick, or heat exchanger, will result in less pressure seen by the map sensor and lower IAT2 on that sensor. It’s a function of the ideal gas law, plain and simple.
So really, boost pressure and temps matter less then power output. But, if temps get excessive, timing is normally pulled which will result in a drastic step down in power.
When the 2650 came out, I specifically asked, twice I think, what the BSFC was. Nobody even tried to answer.
Granted, probably nobody knew the answer but my intent was less about knowing the answer but my failed attempt to get people to understand that you might (likely) will make more (peak) power, but at a cost (independent of capital outlay).
The costs are in fuel, but also in power to drive the blower.
Unless the design of the blower is significantly better than the prior design (not likely), then the added mass alone (and friction) will cost more power (torque) to not only drive the bigger blower but to accelerate those larger rotors.
Let’s imagine the larger rotors weighed the same (highly unlikely)…even then it would cost more energy to accelerate those larger (and less dense) rotors because their center of mass will be further from the axis (think of a spinning figure skater (even a hot one) who moves her arms in and out.
So that’s where I was going with that unanswered question.
Since nobody here cares about using more fuel as long as you get more net power to the wheels, we can choose to not look at fuel consumption from a monetary cost perspective.
But some actually want to accelerate their cars faster, and for this, you need a higher net power over the range that the engine is operating during acceleration.
Which then leads me to this as my own rule of thumb, or perhaps assumption, since I don’t have quantifiable data…
On a 376” engine, I believe you will lose more power trying to accelerate and drive a 2650 blower than you will be able to gain when compared to a well ported 1900 blower over a 1/4 mile pass.
Now, run a 427 and an all out build and I would be hesitant to make that same argument. You have a lot more torque available, plus you have to opportunity to utilize much better flowing heads, so the 1900 becomes a major limiting factor in being able to efficiently transfer the incoming air into the cylinders.
Just food for thought.
Nice post, Steve.Therein in lies the physics which many people fail to realize.
Please notice that everything above is referencedWhen I was first looking at the 2650 I saw that it was more efficient than the 2300 or so Eaton says. I've always wondered how this played into the debate of HP to drive it, IATs, etc. They don't show anything like this for the 1900 vs 2300. Also they don't show the basis for their metrics. For example 18% less input power - is that with or without boost, does this mean it takes 18% less power to drive a 2650 than a 2300 or is it a delta from what they'd expect it to take to drive a 2650, etc.
From Eaton on the 2650:
R2650 advantages over R2300:
- 4% more efficient
- 15% larger displacement (2650cc versus 2300cc)
- 18% less input power required
- 25% more air flow at 18,000 RPM and 14 psi boost (2.0 pressure ratio)
