1 - 8 of 8 Posts
Hey I looked at the original Aeroforce gauge install thread on here but the pictures wont show up on my laptop. Are there any other threads or install instructions on this forum ?:confused:
I faced the same issue when I installed my gauge a few months back. I used this video to see how the console trim is removed:
Here is an install guide:
https://www.diyauto.com/manufacturers/cadillac/generations/cts-v-gen2/diys/aeroforce-gauge-install-by-nathanscott
Here is a wiring tip that someone posted:
http://www.ctsvowners.com/forum/61-how-section/4206-few-pics-my-aeroforce-gauge-install.html
It's not difficult but more tedious than anything due to all the tiny screws you need to remove. I strongly suggest you take note of where the screws came from because some of them are different lengths. Label and take pictures.
Took me about 2.5 hours taking my sweet ass time while sipping on a Gentlemen Jack with a splash of sprite.
Its honestly a piece of cake after that video above. There are many many small screws you have to take out to finally get to the clock. Take your time and have a magnetic tray handy and remember where the screws go (take pics as you go and refer back to them upon reinstall). there are 2 types in the back long and short ones. Also you cn either use the bezel with the clock for the OEM look or use the bezel with the aeroforce. If you use the clock bezel youll have to snip the 2 little plastic posts to get it to sit flush. I then simply hot glued mine in there to hold it in place.
Hmm, every link that i provided is still working including the video. In any case just follow Chaz17 advice and it will lead you right to it.
Max speed, the video in post #2 works fine for me.
1 - 8 of 8 Posts
