My AC stopped blowing cold the last time I drove the V. My brother and I diagnosed the issue to a bad compressor. The clutch is not engaging and will not engage even when jumped at the relay. Threw gauges on the system and both the high side and low side are reading the same at 150 psi. Will I be okay changing out only the compressor or does condenser need to be swapped too?
