1 - 7 of 7 Posts
I can't get my PDF to copy/paste
Only one drain in this illustration of the HVAC box (drain hose is #32, and drain is #53). Make sure the drain is cleared out (cut a larger opening if you have to). Make sure the hose is not blocked and is securely on the box. You will probably have to do that by feel. The hose exits on the driver's side transmission hump about 8'' to the right of the gas pedal. Pull the carpet back – it's visible. It exits underneath the car in the transmission hump, driver's side.
screenshot
1 - 7 of 7 Posts
