Mr Surly. I think you missed this ^.
Try breaking the tire off the bead and rotate it 180. Be very methodical about bolting the beadlock ring on evenly. It’s easy to get it offset on the beadlock side and make it out of round. It won’t ever ride perfect, but it shouldn’t be 10oz out.
Road force balancing a drag radial is a waste. Get a cheap bubble balancer from harbor freight and you’ll get it close enough.
Didn’t miss it. I’m going to try similar asap to see if I can affect the roundness. It would not likely change the out of balance, just relocate the weights, I’ll assume. However,
IF remounting successfully allows the tire to be ROUND, that could affect the vibration and possibly the balance(?)
I was ridiculously meticulous installing the beadlock ring and torquing it AND the lugs.
One thing I might guess is is that somehow, after booting up the beadlock ring, and then airing it up to seat the rear bead… that it got twisted somehow????
My first thought is to remove the bead lock ring, relaxing the face of the tire while leaving the back bead fully seated then reinstalling the ring and see if it becomes round.
If not, then remove the tire completely, clean the rear seat (I had applied ‘sticky tack’ to the rear bead), apply a little tire soap to lube the inner a bit and reinstall 180 out.
I had slightly similar issue immediately after I installed my Billet Specialties drag packs. The wheels shook so bad at about 50mph that it damaged the front lower control arm bushings, and yes, I had to replace them, that sucked! Turns out the front and rear wheel hub on the BS's is larger than the hub pilot on all 4 corners of the car, and who KNEW this can be an issue?? Well I didn't dammit! Hub-centric rings were required to take up the space and once I sourced the right size and installed them, the car has been 129.8mph in the quarter multiple times and smooth as glass!
I don’t believe this is the issue, however if it IS… you have the exact rings I would need! Please send them along post haste!
If the lug nuts are a tapered seat, the wheel is lug centric and not hub centric, so a hub centering ring should not make a difference as long as the wheel is installed and proper star pattern torque sequence is followed in stages. I've run into balance problems before on road course cars with slicks and rings never solved anything, just adding my two cents on my experience, I've no idea why they worked so well in that scenario unless the wheel was somehow getting torqued down oddly? Hmm...
I tend to agree with your thinking
HOWEVER Ill
gladly try
anything.
These Race Stars use a tapered ‘bulge’ seat nut and their bore is 78mm. If I had a quick source I would damned sure put ‘em in there.
All this effort and trial and thought process is trying to get ready to roll out Wed afternoon for the race but so many things seem aligned to shut mt down.
Add to the tire and vibe issue that at the moment Im
at the doctor trying to get what I think is strep throat under control.
I’m reminded as we all sometimes are….. when you can’t breathe, all this other shit doesn’t matter.
So, where can I find the rings? I’ll try them if I can get them, but they won’t fix out-of-round, I have to try some things above for that, or try to find a tire, possibly on the way?
