================================================================================================================================= TDLR: There are a couple hundred posts covering a range of not build stuff topics including a boat restoration(!). To skip all this not build stuff content and go to the actual start of the real rebooted build stuff ten MONTHs in the future (2022!), just click here: The Surly 427 Plan!
Well, here goes. I'm making a build thread for preliminary discussion prior to making changes. I'm doing it this way not because I'm being smart about it but simply because I ordered a few parts, started tinkering and then learned that my job requires that I travel for a while. So I am likely going to be overseas for a month or two so I might as well work on a plan for when I return.
The car: 2011 V coupe BDE Stick Shift Slick Roof 134k miles.
The realistic 'first build' plan: low-level bolt-ons, puley/brick/HX/CAI/ and the required support pieces, maybe pick up 70~80 hp?
The someday "second build" plan: reach 700 rwhp withOUT short block or heads AND remain as outwardly low-key as manageable.
What is done so far:
3" Mid pipes with X, withOUT 2nd cats.
Primary cats gutted.
Z06 wheels and MT DRs
That is ALL, stock everything else right now, air filter to muffler.
HP Tuner bought, I changed the stock file to "no mil" on 420 and 430 (cats)
What I have ordered:
2.5" Mepco pulley
solid isolator
AFE Momentum gt CAI
What I planned before being called away:
Install isolator and while I'm in there (here we go...) port the blower and the snout, add the pulley, reinforce the brick
Next on my mental list to acquire:
heat exchanger
HX pump
It's been suggested that I'm severely lacking in my plan.
Feel free to offer direction!
2.5" Mepco pulley
solid isolator
AFE Momentum gt CAI
heat exchanger
HX pump
