What happened:
I suffered a collapsed lifter about 200 miles past my last build in October 2021 probably due to a failing cam bearing. I'm not sure if this failure was due to possible install error for my new cam and heads or just plain bad luck and there was an underlying issue all along prior to my last round of mods. Whatever the case maybe I decided to rebuild using another performance shop over the last several months.
Fortunately for me the 416 crank and block could be reused and was still in good shape. The crank was re-polished and the block was bored and honed. The engine builder also replaced all the bearings (main, cam and rod) and installed new LS2K Diamond racing pistons with 9.5 Compression ratio 4.080 bore -18cc.
Unfortunately for me the brand new custom stroker cam I bought from GP tuning was damaged on one of the lobes from the failed lifter, so I had to procure that same cam again from him. I also had to buy a new set of lifters and this time I decided to go with Johnson 2116r lifters (previously had 2110r lifters). In addition, I had to buy another brand new 10355 replacement pump due to any metal that might still be in my old pump.
What's new:
Since the engine had to be rebuilt, I had my new shop contact LME and they said this engine is good for 1000whp, but recommended I stay under that number for longevity and durability.
So with that news I decided to make the following changes:
Goals:
I was pretty happy with the power my car had, but I wasn’t happy with the way my car shifted during normal driving during the short time I had it. This time around I just hope the car operates and shifts/drives/starts smoothly and that I will have a safe (not to aggressive) tune.
My previous build made 889whp and 783wtq on E and 813whp and 715wtq on 93.
I hope with addition of a smaller upper pulley and meth that I’ll see some gains. Derek likes to tune conservatively on 93, so I don’t expect a big bump there even with meth. However, I do expect about 30-40whp and about another 50wtq with E. I don’t want to speak to optimistically because I have been somewhat disappointed on my last predictions and don’t want to set myself up with another disappointment.
What's new:
- I increased my 2650 pulley combo from 3.0/8.6 to 2.625/8.6
- Added an Alky Meth kit w/3 gallon in trunk tank
- New motor mounts
- Get the Holley Hydramats I previously purchased for the Fore kit installed (was never installed on my last build even though they were provided)
- Use Derek Dunbar as my tuner going forward
Goals:
