1 - 20 of 35 Posts
It's been a while since I started doing research on this project & I posted some questions concerning parts choices a while back.
Originally a 305/700-R4 with about 190 HP. I cruised it around in the summer months,
It handled great but was not as fast as the average minivan, although it cornered really well.
After driving it in relatively stock condition for over 5 years, I started a full rebuild of this car in 2011 & completed it in 2014.
The factory clear coat was starting to come off, so it was time to rebuild / start modifying.
To bring progress up to present day, I'll provide some history.
I tore it down to a bare shell with basically only the dash wiring remaining in the car.
The underside was really clean, so I repainted it along with some suspension upgrades.
A lot of lacquer thinner & rags took it to the original primer.
Hood Automotive lighting Motor vehicle Automotive design Car
Then for some fresh paint... no use painting the top only to leave the underside all ugly.
Tire Wheel Vehicle Automotive tire Hood
Tire Automotive lighting Hood Automotive tire Motor vehicle
The factory 10 bolt got upgraded to a 3.54 geared Strange 60 rear with 35 spline axles.
Automotive tire Motor vehicle Vehicle Road surface Automotive exterior
I also added a Watts link for better handling along with some Koni shocks, better springs & frame connectors.
Bicycle part Automotive exterior Auto part Bracket Metal
All this was underway, but still no engine....
I did not want to build another race car & insisted to make a very drivable vehicle.
I originally wanted a LS7, but there were none out there for a reasonable price... the LS9 was not in the plans as of yet.
A T-56 6 speed was acquired for a little driving fun over the factory auto.
I'll follow up with some more build pictures to get closer to present day.
Nice! A buddy of mine had one in high school, it was a pretty fun car, even with no power! Haha haven’t been in one for twenty years, but it did seem to handle very well. Looking forward to the updates.
The front end got some sand blasting to clean everything up.
Plant Tree Grass Sculpture Art
Plant Motor vehicle Automotive tire Automotive design Bumper
Modifications were needed to clear the AC compressor... I'll never build another car without AC.
Helmet Automotive tire Tire Motor vehicle Bumper
Finally with some paint.
Plant Tree Swing Grass Sky
Plant Tree Automotive tire Motor vehicle Grass
Used Global West Del-a-lum (aluminum/Delrin) bushings in the front & extended ball joints along with 800# springs to make sure handling is up to par.
Electric blue Auto part Fashion accessory
Added some sound deadener inside.
Hood Automotive tire Automotive lighting Motor vehicle Bumper
Then I finally found an engine... a 2011 Camaro LS3 with only 11 miles on it.
It turns out that Nickey Performance was modifying new Camaros & a customer wanted a built engine so the car was driven straight from the dealer & the engine pulled.
Tire Wheel Automotive tire Motor vehicle Bumper
Discussion Starter · #4 ·
Once I found a good engine, I couldn't leave it alone..
I immediately ordered a cam & valve springs along with a 92mm throttle body.
A set of 2" long tube headers (with the long-term intention of forced induction) were ordered also.
I originally thought a Procharger would be a relatively easy to add in the future.
Automotive tire Motor vehicle Hood Automotive design Automotive exhaust
Automotive tire Motor vehicle Machine Automotive wheel system Rim
I also freshened up the under-hood area to complete the engine swap.
Hood Automotive lighting Motor vehicle Vehicle Automotive tire
Installing the engine from underneath is so easy... I just rolled it under the car on a 4-wheel dolly & lowered the body over it.
It was actually done with the car on jackstands as I did not have a lift at the time.
I also upgraded to a 99-02 Camaro plastic tank so I no longer had to worry about alcohol-based fuels along with a -8 teflon supply line & -6 return.
Revolver Trigger Gun barrel Automotive exterior Bumper
Suspension was installed & it was getting close to a running vehicle.
Motor vehicle Automotive tire Automotive exterior Bumper Automotive wheel system
Vehicle Hood Automotive tire Motor vehicle Automotive exhaust
Fuel tank Automotive fuel system Automotive lighting Motor vehicle Automotive tire
It got new seats, carpets, headliner & all new weatherstripping.
Wheel Tire Vehicle Car Motor vehicle
Had to swap the gauges since the factory 6K tach & 120mph speedometer was now useless.
The speedometer still too low as it touches the 6700 rev limiter at 144mph in 4th gear.
Gauge Speedometer Tachometer Measuring instrument Motor vehicle
With it finally back together, I drove it this way for 3 years & also got a few car show trophies.
Car Vehicle Hood Motor vehicle Automotive exterior
Wheel Tire Car Vehicle Automotive parking light
It was very fun to drive & every Mustang wanted to race since they thought it had no more than 245hp.
Discussion Starter · #6 ·
So, three years later...I decided to purchase an S10 Xtreme, which I also posted some build pictures of on this site,
It was a 4.3 V6 5 speed, which was a perfect platform for the LS3/T56 in the Firebird... so the Firebird was engineless for the time being as the S10 got built.
I had picked this up around 2017, prior to the S10 purchase but thought it may be better suited to the Firebird.
Tire Wheel Motor vehicle Vehicle Automotive tire
Motor vehicle Automotive tire Automotive exterior Gas Automotive wheel system
I tore it completely down & planned a good rebuild with some modifications.
Automotive tire Product Motor vehicle Automotive wheel system Automotive exterior
Then Covid hit & I could not get any parts, so it sat largely like this until recently, when I got the urge to start building it again.
Neat project and you have good skills.
Reactions: kittyboy
Discussion Starter · #9 ·
Before doing anything else, I set the supercharger on the LS3 while in the car to see if it clears the hood.
There is about 1/2" clearance at the front corner to the under-hood bracing.
The throttle body looks to be a challenge & I may have to fabricate an elbow to go between the throttle body & the supercharger...
This looks to be better than making a very sharp 90 in front of the throttle body.
Unfortunately it points up & forward instead of at an angle to the left like the LSA.
The LS9 engine itself ended up being quite a challenge to make it work in the car.
The dry sump oiling system (pan, lines & oil tank) will not fit in the car without major surgery, so I chose to convert it to wet sump.
Some internet expert said... "It is just like a LS7... shorten the crank snout, buy an oil pump & drill for a dipstick"
Unfortunately, this was not the case.
The crank snout is the same length as a LS7 but since the engine is supercharged, the keyway is located farther forward to drive the dampener & also locate the timing gear, instead of just a keyway under the timing gear. When you put on the shorter oil pump drive there is no means to locate the timing gear.
Also the crank is normally a few thousandths larger where the timing gear is located, but on the LS9 this area extends up to where the dampener was normally located.
What that means is the end of the crank needs turned down to so an LSA style dampener & oil pump drive will fit.
While the crank was being shortened & the snout turned down, I had a full-length keyway installed from the timing gear to the front edge of the crank.
Hopefully this will reliably locate the dampener under high boost ober the short factory keyway.
Discussion Starter · #10 · (Edited)
I've accumulated a bunch of stuff preparing for the build.
Motor vehicle Automotive tire Shipping box Automotive design Automotive exterior
Unfortunately, I cannot find a picture of the crank prior to machining, but here is the crank after modifications.
Product Circuit component Electronic component Gas Auto part
You can see the area that was turned down about 1/2" forward from the main journal.
Automotive tire Bicycle part Rim Cylinder Machine tool
Hood Automotive lighting Bumper Automotive design Material property
Bicycle part Gas Auto part Machine Nut
Discussion Starter · #11 ·
I had the block line honed after installing main studs.
The studs distorted the journals .0008 maximum.
Gas Engineering Machine Auto part Cylinder
New cam bearings installed.
Tire Wheel Light Automotive tire Locking hubs
Here is a look at the factory pistons & rods.
They are quite different than the LSA...
Aside from the rods being titanium, the piston pins are a larger diameter (.984") & the rods are 108" shorter.
Font Gas Metal Household hardware Auto part
Discussion Starter · #14 ·
It is finally coming together.
ARP rod bolts were a small fortune.
Motor vehicle Gas Automotive wheel system Automotive exterior Machine
Another interesting thing is the engine was not drilled for a dipstick.
They sell a $90 jig to drill it, but after a quick look, there is a flat pad where it belongs.so I measured the dip stick for the proper diameter & started drilling.
Photo is obviously out of order & was done before the short block was assembled.
Black Wood Grey Font Tints and shades
I found the cam to be off by 1 degree when I checked it, so the multi-position crank sprocket came in handy.
Since I'm going with a Holley EFI system, I also installed a timing pointer to verify timing while running.
I also used a small diameter AC pulley to allow me to keep the AC engaged at high RPM since I plan on running a chiller.
Tire Wheel Automotive tire Motor vehicle Tread
Getting ready to install the heads.
Motor vehicle Bumper Gas Automotive exterior Machine
Discussion Starter · #15 ·
I ordered my Rossler Transmission's 4L80E with trans brake.
They are backed up about 2 months.
Still trying to pick the proper converter.
It will be a triple disc lockup for sure, but not sure what stall to go with.
It seems like i should not need with too high of a stall due to the available low-end torque.
I'm guessing in the 25-3000 RPM range.
Another issue was finding a 9-bolt flex plate, as all ZR1's were manuals.
JW Performance Transmissions makes a custom one... they built & shipped it within 3 days.
It sucks that I had to buy 2 packs of ARP bolts as they do not offer a 9-piece bolt kit for an automatic flex plate.
· Vendor
With a 2.48 first gear Id go 3200 or so.
Discussion Starter · #19 · (Edited)
3200 should be abut perfect for that with a 4L80 and reasonable PD blower cam
What is the max RPM you typically pulley the LS9 superchargers to?
I have a 9.55/2.6 on there now which will be overspinning it at high RPM.
I'm guessing it will make peak power at 66-6800 but will be able to rev much higher if necessary.
I'm planning E85 & a chiller to keep the air as dense as possible.
Cam is mid 230's/upper 240's on a 120 with .630/.600 lift.
Unfortunately, compression is only 9.25:1 as I did not want to excessively mill the heads or change pistons, which would have required a custom piston due to the odd length rods & pin size.
Once that process started, things would have escalated to a different rotating assembly, then different block, then a different charger, killing the budget part of this build.
I really only started this build due to the good deal I got on the engine & I must now resist the urge to get too out of control.
1 - 20 of 35 Posts
