1 - 20 of 48 Posts
That’s impressive! What are you expecting with the blower?
Theyll probably run 20psi, accounting for losses should be in the 1050 to 1100 range with adequate cooling (flywheel)
Sure Matt, just trying to hurt Jesse’s feelings now! ;)
Reactions: random84
I'd love one of those if you have any extras laying around you don't need..
What pulley ratio are you going to run?
Enough to make more power than you, grandma! ;)
The 400ci engine showed up Currently have 3.0 and 2.75 upper pulleys along with 9.55 and 9.77 lower pulleys for options to play with.
Specifics on the engine? Which crank and rods?
Are you using adapters for the heads to the blower?
That was a mistake on the paperwork. LS3 heads.
Reactions: EFoxwell
I feel like a peasant with my Callies Compstar CCW crank. And holy piss I just got to the rods and piston section.....gas ported....nice.
Things escalated quickly
1 - 20 of 48 Posts
