Is anyone running any aftermarket suspension parts to help with traction at the track?930hp on E85
I bought car out of salvage pool all I know is it has a Kong 2650and it's been stroked to a416 with bigger bottom end he was going to go bigger ontop end.if you ask me it don't need anything else.maybe there is a way to hesitate the throttle so it don't give it all at once.i don't know it also has a custom ground bullet cam H beam one thing rods ported and polished heads and blowerhas a separate cooling container and pump for superchargerWhat are your build specs?
Well asshole I do speak english.i didn't get on here to have my typing graded and I'm sure you are not the sharpest tool in the shed but just for the record I'm disabled smartassNot sure what language you speak, but you don’t type in English.
Nevertheless, you can modify the spark advance tables so you don’t produce as much torque and therefore soften the ‘hit’.
Well, that's a little harsh. For the record, I speak English and you speak American. 🤭 You're still missing some punctuation and have some syntax errors.Well asshole I do speak english.i didn't get on here to have my typing graded and I'm sure you are not the sharpest tool in the shed but just for the record I'm disabled smartass
Karch is a good guy with a somewhat / sometimes dark sense of humor.Well asshole I do speak english.i didn't get on here to have my typing graded and I'm sure you are not the sharpest tool in the shed but just for the record I'm disabled smartass
Mickey Thompson won't hold either I've already tried them a hoosierfull blown drag slick does the job.thanks for Everybody grading my typing skills like I said I am Handycap so there are probably several things y'all can do better than me.BUT IWith 950 rwhp, seems like he'd have to be running MT ET streets. I can't see any other tire holding that much power with out a prepped track. I'm not even sure the ET streets can hold that much power without a good tune ramping the power up linearly. If it hits all at once, it's going to be a smoke show.
Who said anything about the street..Karch gave you an answer on how to soften the hit but with 950whp, no tire will give good traction on the street with heavy throttle input. Drag setup on a prepped track is where you'll find traction.
I tried that to but the fuckers were closedWhen I had no traction, I went to the traction store and got some.
Are you sure you speak English ? It sounds .mWell, that's a little harsh. For the record, I speak English and you speak American. 🤭 You're still missing some punctuation and have some syntax errors.
You can take your free pass and stick it up your fucking ass you fucking little prickI’ll give you a pass on your profane comments, but this is the last pass you get.
And I’m definitely not the sharpest tool in the shed, but if this thread is to be used as a guide, at least I can take pleasure in knowing I’m not the dullest tool here.
