1 - 3 of 3 Posts
Have 70,000km on my 11' sedan and A number of issues have started to arise which im addressing on the forum before my 80,000km warranty is up.
When downshifting in most gears (say 3,000rpm in 3rd to 2nd or 4th to 3rd) the car downshifts, then almost exactly 1 second later hesitates or stutters causing the car to almost jolt and the RPM's to stutter as if it wasn't fully in gear or there is play between them?
Also, when in any gear (say 2500 rpm) when putting my foot flat, there is a loud "Clunk" or "bang" from the transmission as power is applied, its not smooth as i once remembered it to be.
Am i going crazy? I remember the shifts being rough, just not like this...
Converter
I had the same issue from 2-3 gear with slamming into the next gear. They replaced my torque converter.
I still get that jolt thing some times ..usally after going down a few gears too fast
Can anything aftermarket be done to fix the issue? Ill be taking mine in to have this replaced ASAP
1 - 3 of 3 Posts
