1 - 4 of 4 Posts
Drove my car to the daycare and then the gym and all was fine. Got in the car to go home and bam, I’m getting light on the dash. Check drivers assist, parking brake, brake etc all on. CEL then came on and now the car will not shift out of first gear. Tried checking codes and there weren’t any. Tried clearing non existing codes and everything was fine for a few minutes. Then bam same thing. No codes, no shift out of first and no clearing non existing codes. Also none of the gages are working on the dash. Heeelllppp!!!!!
Holy cow. This car has issue after issue after issue. Clean and inspect EVERY ground on heads, frame, and battery.
Man you ain’t lying. I disconnected the battery for about an hour and now it seems fine. More to follow though
I had a similar issue after going full bolt ons . Car would drive fine for about 30’mins & then stick to first gear . Turned out to be when I deleted my hard lines & went to a trunk tank one of the studs to bolt down the line was touching with my harness to ecm . Moved & retaped it & it took care of the issue
1 - 4 of 4 Posts
