1 - 5 of 5 Posts
So I’m still learning features on my 09. Picked it up back in February. Owners manual says it displays trans temp in the DIC. I can’t find it though, is this a feature that needs to be programmed? I can’t read the temp through my aeroforce gauge either. I tried the search feature but only had look with automatics
Pretty sure that is only for the A6
Reactions: adam112
yea no TR6060 temp info
Biggest things on these trans are oil starvation under launch/ sustained road course Gs. Starves the front of the case and the suspect 2nd gear synchro can burn up. My methodology was always to monitor Oil temp (which is calculated based off of driving, not a sensor) and once it reached >150F good to go wot. I wouldnt worry too much about M6 temp. If you have a solid reason to be concerned, you could add a sensor somewhere along the cooler circuit. @flyingv is probably the hardest on these transmissions and might have some input for true abuse conditions.
1 - 5 of 5 Posts
