The issue for me with the Corvette wheels is that the Corvette front wheel is 1" shorter than the back. Corvettes since the C5 have a stagger (my C5s had 18" rear and 17" fronts, but they both went up an inch with the C6 and then again with the C7). So on the Corvette the front tire is smaller diameter than the rear. (not sure about the C8). But the Caddy does not have a stagger, the front and rear tires are the same diameter. So when you use Corvette front wheels up front on a V, you have to run a taller sidewall to compensate for the smaller diameter wheel. I don't like that look. It should be the rear tires that have the taller sidewalls, if there's going to be a difference at all. So IMO you really want to run 4x Z06 rear wheels all around...
Well, it IS a long thread that linked above and I don’t blame you for not reading it.
The detail revealed in that thread is that
I shared your issue in that I had the same dislike for the 18” fronts.
SOoooooo I found aftermarket REPLICA wheels for the fronts
specifically to fix that. OEWHEELSLLC makes the design available in seven or eight sizes
that Chevy never sold to cater to the F-body and narrow-body Vette crowds.
The rears are OEM 19x12s and the fronts are copies in 19x10. The front tires are 285s exactly as originally used on the rear. The tires are all the same height, same sidewalls.
Hopefully it doesn’t have the weird look of staggered heights as the tires are within an eighth-inch OD.
