Alright, I've been working on this car for quite some time chasing what i thought was a drive line vibration. This started early 2020 and has been getting worse, yet more refined as of late.
As a reference, the modifications necessary to follow this post are as follows:
It's a higher-frequency vibration which does not correlate with engine speed nor whatever gear i am in - it is solely affected by ground speed, and appears at approximately 80mph on-wards.
As always, I started with the simple checks: tightened lug nuts, loose body panels, wheel imbalances, etc. etc. etc. Balanced, re-balanced, and balanced again. Not the issue. Frequency of wheel imbalance is much lower than what I experience.
Messing around one day, i noticed the tone generator app on my phone and it gave me an idea: see what frequency the vibration is at speed. Turns out to be around 75Hz at 80mph. This got me thinking and I then did some math to attempt to figure out what may be spinning at that frequency, and it turns out the driveshaft spins at ~4500rpm (or 75Hz) and climbs with the ground speed.
Aha! This must be the problem.
I pulled the driveshaft and had a shop take a look. They found bad u-joints (only in one axis somehow?) and put it on the balancer. Threw the driveshaft back in the car...and the vibration was still there. So i took the driveshaft back and had them inspect it again; this time, the driveshaft took weight to balance (weird).
Still didn't fix the vibration.
From there, i decided to check out the rear end because it was making noise on accel (a sign of a bad pinion bearing?) and drained the gear oil. That oil was on-par with the black diamond tri-coat which was NOT good. On top of that, the diff housing was effectively wedged against the rear subframe, potentially making the vibration transfer even worse! Luckily, GForce willingly took the housing back and redesigned it with new hardware to make it fit just right. I also got a new gear-set with bearings and seals from Strange. Threw everything together to-spec.
This still didn't fix the vibration.
I am getting fed up and more annoyed. The car makes north of 700 whp on corn and i am limited by this vibration which gets worse after 80mph!!!
I had my driveshaft shop build me a custom 4" one-piece which has billet 6-bolt flange to 1350 u-joint coming off the trans, and a 1350 yoke for the Strange 3rd member. I know that thing is silky smooth, but i still get the high frequency vibration.
As of last weekend, I have replaced all four hub bearings and completed a rotor and pad job (thanks for the 2-piece rotor posts!). I found during this job that the inboard CV on the passenger side had a severely ripped boot and the grease was like clay...
GForce had me send the axles back for inspection and confirmed my concerns about the bad CV, and are currently RMA'ing both axles.
Could this be the culprit? I am in no way familiar with how CV's behave on our cars.
I also have a set of BC Forged wheels which were delivered yesterday, so that will be a fresh slate to drive on.
After replacing the differential parts and installing the new driveshaft, the vibration seemed to be more refined - as in, extremely repeatable. When cold, it comes in at 85mph and gets progressively worse, with the vibration intensity being more severe in between the engine driving the wheels and the wheels driving the engine (almost like in between gear lash). But it doesn't dissipate when decelerating. Only below 80mph.
When the car is warm (having been driven around for ~30 minutes), the vibration creeps in around 78mph and the intensity is worse from then on. Definitely affected by component temperature(s), whatever that's worth. The vibration does not show anywhere else in lower ground speeds, only at and above the speeds mentioned prior.
So, to recap, I have
If the axles do not solve the issue, I'm really not sure where else to look next. I would hate to have to tear into my transmission, but it seems unlikely due to the nature of the vibration itself.
If there is any one on here that can shed some light on something i may have not thought of, PLEASE let me know. I want to get back to doingfreeway pulls the speed limit!
- GForce 9" IRS kit w/ Outlaw axles
- 4" Aluminum one-piece driveshaft
- Strange aluminum 3rd member
- GForce IRS housing w/ plate front mount
- Red poly bushings
- VMR V810 wheels (19X10.5 R / 19x8.5 F)
- Monster Triple Disk Clutch
- Stock manual trans
- Balanced, re-balanced, and balanced my wheels
- Had the original one-piece DS inspected and balanced twice
- Had a new one-piece DS made (bitchin' job AZDS!)
- Replaced the subframe bushings with black poly (much more planted rear end w/ minimal noise intrusion)
- Rebuilt my entire 9" with new gears, seals and bearings
- Had GForce inspect the diff housing and correct improper housing placement within the subframe
- Replaced all four wheel bearings
- Installed all new rotors and pads
- Ordered new wheels
- Sent axles back to GForce and am awaiting their return
