1 - 12 of 12 Posts
Hey everyone,
So i got this message on my dash after the last time i took my car drifting, car seems to be fine when cruising but i get this message when i floor it or drift it again, another thing is that i get the yellow e brake sign on the left when i hit a pot hole and yes i read about it and cleaned and greased my sensors no luck still acts the same plus all connections are okay even the ground on the intake side.
Check brake fluid level. I got that suspension error as well as a brake error when I put my foot in it.
Check your motor mounts man...the DS is known to fail at stock power levels...the drifting is likely only amplifying the issue. Motor mount issues can cause any number of problems from coils banging the strut tower, to blower lid hitting the hood, yellow tcs warnings etc...
I like the videos!
Edit: Also check your lower control arms up front, they are notorious for coming loose and move while driving.
Discussion Starter #6
I like the videos!
Motor mounts are okay, brake fluid is full. Ill try to put the car on the jacks as soon as possible to check lower control arms.
Thanks
The dealership read the code when mine had that....it was a left rear shock. With me assisting a friend who had already done them on his, we replaced both rears for the price the dealer wanted for one.
Discussion Starter #8
If thats the case then im ready for some kw or bc coilovers.
With your drifting...that probably will be a good thing.
Reactions: Ruthle55
Discussion Starter #10
Hey guys i figured it out, it was the ground on the drivers side (G110) it was tight but it wasnt doing its job properly so i took the bolt off cleaned the threads and replaced the bolt. its all good now
thanks for the help.
You mean the ground under the intake, right? That thing has bitten more people than I can count.
Discussion Starter #12
Yeah its the same one, I tightened mine and still triggered the same error, i changed the bolt and cleaned the thread. Its all good now.
I asked a couple of people they told me change your abs module or shocks.
1 - 12 of 12 Posts
