GM Special Coverage Adjustment – Supercharger Warranty Extension - Page 6
Page 6 of 6 FirstFirst ... 456
Results 151 to 166 of 166
Like Tree28Likes
Thread: GM Special Coverage Adjustment – Supercharger Warranty Extension
  1. #151
    Active Member
    Join Date
    Sep 2016
    Location
    North Central Oklahoma
    Posts
    67
    I got mine done last week. Bone stock with 25K on the clock. '14 BDT Sedan.
  2. #152
    Active Member
    Join Date
    May 2016
    Location
    Pacific Northwest
    Posts
    970
    Quote Originally Posted by moveovr View Post
    How does she feel? Mine seems to pull stronger.
  3. #153
    Active Member
    Join Date
    Jun 2012
    Location
    Adult Film Set
    Posts
    17,166
    Quote Originally Posted by SimplyDreamin View Post
    I noticed the same when I had the SC replaced on my first V wagon...the Gray Whale. Seems a lot of people had poorly adjusted relief valves or something. Main issue was some weren't making full boost.
    SimplyDreamin and MYV like this.
    CTS-V: Celebrating 3 generations of N.F.G.
    Because groceries deserve LS power, too!
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #154
    Active Member
    Join Date
    May 2016
    Location
    Pacific Northwest
    Posts
    970
    Quote Originally Posted by TriTexan View Post
    I feel the need to Dyno again. That was a fun day. Maybe I’m closer to 515 hp at the wheels. Also, I found a gas station with 93 and no E (I’m not flex), add some booster, and waste some tires.
    From all my reading, I did not know you had a Gray Whale, Eric.
  6. #155
    Active Member
    Join Date
    Nov 2018
    Posts
    89
    Just had mine done at 58k miles, and I feel a difference too.
  7. #156
    Active Member
    Join Date
    Apr 2018
    Location
    Armpit of TX
    Posts
    136
    I called the local Cadillac house and have setup an appointment on Monday to check out my S/C noise, apparently it "whines" too loud I'll let you guys know how it went
  8. #157
    Registered User
    Join Date
    Dec 2015
    Location
    Connecticut
    Posts
    36
    Just had my SC replaced, 50k miles. I don’t feel any difference in power, but it quieted down the rattle/knock on cold start. Took about half a day (and a dubious 9 miles worth of test driving).
    2014 CTS-V Wagon 6MT Radiant Silver | Airaid w/Green Filter | VS Forged VS08 19/265 19/305 | Moroso catchcan
  9. #158
    Join Date
    Nov 2012
    Location
    Posts
    16,263
    The initial boost increase goes away once the SC breaks in, then back to normal.
    MYV and auminer like this.
    679RWHP 662RWTQ
    BMF cam
    Ported SC/Snout/90TB
    Kooks LT w/cats stock muffs
    ID850's
    IW 9.1/2.55
    Airaid w/green filter
    Katech+W4M HX ZR1 pump
    Norcal ice tank
  10. #159
    PPV
    PPV is offline
    Registered User
    Join Date
    Jun 2016
    Posts
    12
    Ugh been waiting on parts for over a month to have mine replaced. GM strike is holding up parts.
  11. #160
    Join Date
    Nov 2012
    Location
    Posts
    16,263
    Quote Originally Posted by PPV View Post
    Sounds like the UAW vote is leaning towards rejecting GM’s offer and the UAW will strike both Ford and FCA.
    679RWHP 662RWTQ
    BMF cam
    ID850's
    IW 9.1/2.55
    Norcal ice tank
  12. #161
    Active Member
    Join Date
    May 2016
    Posts
    68
    I just had mine done. The dealer here in Connecticut was able to get a dealer in Texas that had about 20 in stock to send one up. Not sure how or why they did but at least there are some still on shelves
    MYV and Rumdig like this.
  13. #162
    Active Member
    Join Date
    Apr 2018
    Location
    Armpit of TX
    Posts
    136
    Quote Originally Posted by Typhoon92 View Post
    Because Texas > Rest? Lol. Hoping I can have the same luck as you...
  14. #163
    Active Member
    Join Date
    Apr 2018
    Location
    Armpit of TX
    Posts
    136
    This morning, while sitting in line to get into work, I noticed the sound of my isolator (I sure hope that is what I was hearing) from inside the cabin, cutouts open as well. It sounded as though a ferocious rat was trying to escape a wooden box, somewhat of a scratch and tick all in one. The temperature was the coldest I have driven in with this car, ~25 degrees out.
    I was quite surprised to hear this noise from inside the car.
  15. #164
    Active Member
    Join Date
    Nov 2013
    Location
    Watauga TX
    Posts
    3,066
    Quote Originally Posted by Rumdig View Post
    Or because TX=The V capital of the world.
    Rumdig likes this.
    2013 TG Sedan
    ID1050x's, 2.4 griptech/8.66 lower, GP 2.5 cam, AEM drop in pumps, custom added Walbro 450 pump, DSX flex fuel sensor, DMS Auxiliary Fuel Filter, Track Attack HX, CWA50 pump, ZL1 Lid. 90mm TB, Kooks catless headers, Airaid with green filter, Moroso catch can, AFR500v2 wideband, tuned by Pat G/Me.
    2011 BDT Sedan
    ID850's, 2.4 upper, Track Attack HX, Varimax pump, ZL1 Lid, Texas Speed headers, Airaid with green filter, Moroso catch can, LPE tank, PLX wideband, tuned by Pat G.
  16. #165
    Active Member
    Join Date
    Apr 2018
    Location
    Armpit of TX
    Posts
    136
    The stealership agreed that the sound was originating from the S/C and have arranged to replace it. They gave me a XT5 as a loaner (not impressed) and I should have the V back in a few days.
  17. #166
    Active Member
    Join Date
    Apr 2018
    Location
    Armpit of TX
    Posts
    136
    I received the car back from the dealership on Saturday with a new shiny part installed. No more noise originating from the frontal engine compartment (for now). It seems as though the boost does come on a little earlier and rises ~0.5 - 1 psi higher but it could be the cool weather. I'm sure it'll be back to normal after the break in as Larry suggested. I also took a glimpse of the work order package that the clerk was processing, it had a grand total of $3,885 for parts, my estimates were considerably lower.
    And so much for my swirl free paint correction (was half way completed) as there is new scratches where the fender covers were placed and along my passenger door. Nothing that a quick buff won't remove.
    SimplyDreamin likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
2011 cadillac cts v supercharger rattle
cadillac cts special coverage 14264
cadillac special coverage 14264
cadillac special coverage 14264 warranty
cadillac warranty special coverage 14264
gm special coverage adjustment
gm special coverage adjustments
gm tsb 13313
lr058080
special coverage 13313
special warranty 13313
Back to top
