Mobil1 M1-212A oil filter ???
Results 1 to 15 of 15
Like Tree4Likes
  • 1 Post By Sommer86
  • 1 Post By URPREY
  • 1 Post By URPREY
  • 1 Post By URPREY
Thread: Mobil1 M1-212A oil filter ???
  1. #1
    Active Member
    Join Date
    Nov 2016
    Location
    Mid Mi
    Posts
    1,815
    Anybody know if the M1 212A filter will fit the 09 V, I know the M1 212 will but not sure about the M1 212A, Amazon says it won't fit ... Thanks
    2009 TGC Sedan / A6 / Bolt On's / Tuned Throttle, Tran's & for E85/ 635 RWHP 645 RWTQ On 93 Octane 700+ RWHP 700+ RWTQ On E85 / Photo Album ... A man who carries a cat by the tail learns something he can learn in no other way
  2. #2
    Active Member
    Join Date
    Mar 2014
    Location
    NY
    Posts
    59
    Yes it's the same filter, just the newer model. I think most of the Mobil 1 filters now end in A. Supposedly the older filters were made a bit better and also cheaper, but still a great filter.
    Sent from my Pixel 2 XL using Tapatalk
  3. #3
    Active Member
    Join Date
    Nov 2016
    Location
    Mid Mi
    Posts
    1,815
    Thanks ...
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Jan 2013
    Location
    Burbank, Ca
    Posts
    1,182
    I have an A6 '09 and run the M1-212A. It's the "taller" version of the 212. It absolutely fits, and even though its "taller", it's still protected easily by the depth of the oil pan. It also allows for a bit more oil to be held. I run a full 6 quarts with the 212A, it's a great filter. Order it from Walmart, It's $4 cheaper than autozone, O Reily, etc.
    iVwishing likes this.
    SHE'S FOR SALE: 2009 CTS-V - Fully forged motor with forged Callies rods and Wiseco pistons. WCCH "2.5 heads", GP Tuning's "2.5" cam, Johnson 2110's, C5R timing chain, Straub Trunions, WCCH Ported Super Charger w/ a 2.45, ATI pulley w/ a lingenfelter 8.6 lower. ID850's, 2" SW Headers, milled ZL1 lid w/ ported fittings and a reinforced brick. Vadder "black" Destroyer HX, Varimax pump handle the cooling. I have all receipts.
    Induction is an Airaid w/ the Green filter, 102mm TB. She also has 5K foglights , Powder coated wheels, Slotted R1 rotors, black Gorilla lugs, and a PAC Nav Unlock.
  6. #5
    Active Member
    Join Date
    Feb 2015
    Posts
    441
    K&N version is HP-2011
  7. #6
    Active Member
    Join Date
    Apr 2014
    Location
    San Diego, CA
    Posts
    267
    That's the same filter that I have been using for years.
    Most of the guides will tell you it doesn't fit because it's a bit taller than the OE filter... This doesn't matter with our cars, we have tons of room under there.
    Just don't forget to factor an extra 1/2 qt of oil when you refill.
    2011 "Black Diamond Edition" CTS-V Coupe
  8. #7
    Registered User
    Join Date
    Sep 2019
    Posts
    5
    I believe on the Mobil filters, the difference would be that the ones that end in A, is that they are the annual filters vs every oil change. They are extended life when used with their extended synthetic oil. They claim 15,000 miles or 1 year along if I remember correctly. So, they say the oil and filter when used in that combo will last up to 15,000 miles.
    Sent from my SM-G955U using Tapatalk
  9. #8
    Dat ass
    Join Date
    Jun 2013
    Location
    Louisville, KY
    Posts
    1,667
    Quote Originally Posted by Cidewayz View Post
    I can't imagine trying to save $10 by not changing the filter when I'm doing my oil change.
    RobF300 likes this.
    2011 CTS-V Coupe: 659whp/598wtq on E60 - Tuned by WeaponX! M6, silver hardtop, gloss black roof, titanium Recaros, Airaid, gloss black MRR228 20x9/20x11s, red calipers, WeaponX carbon splitter/side blades/fog light buckets, rear inserts, D3 rear diffuser & Bladewing, Core Shifter, WeaponX Track Attack and Low Mount HX, Eibachs, QTP wireless cutouts, 2.55 pulley, ID850s, ported snout, Mamo TB, NGK TR7IX, ZL1 lid (milled and powdercoated), Pinnacle Coolant Tank, DSteck E85 sensor, SideSwipe LSXTV article on my V
    1999 Firehawk Trans Am #156 of 719: M6, red/tan t-top, cam only
    2017 Focus RS2: (Daily)Stealth Grey, HRE FF04s, TunePlus, ECS Intercooler, AccessPort
    2010 CTS Sport Wagon Premium AWD: A6, maroon/tan - wife's ride
    2014 Fiesta ST: project car for my daughter
    2015 Fiesta ST: my project car
  10. #9
    Active Member
    Join Date
    Jan 2013
    Location
    Long Island, NY
    Posts
    12,263
    Quote Originally Posted by URPREY View Post
    switch that around, change filter 2 times oil once
    oil has gotten expensive but its still cheaper than engines
    2014 Phantom Grey sedan lots of mods
  11. #10
    Dat ass
    Join Date
    Jun 2013
    Location
    Louisville, KY
    Posts
    1,667
    Quote Originally Posted by RobF300 View Post
    Ah that makes a bit more sense. Still seems like a bad idea to save $30 worth of oil vs a $10 filter
    RobF300 likes this.
  12. #11
    Registered User
    Join Date
    Sep 2019
    Posts
    5
    The way it read to me is both the correct oil and filter when used together, can last up to 1yr/20,000 miles whichever comes first. I personally will be changing my Vs oil each cycle, but on my DD (Honda Accord) I'll run 2 oil cycles before I changing it.
  13. #12
    Active Member
    Join Date
    Apr 2016
    Location
    Michigan
    Posts
    152
    put whatever you want on the packaging and protect your butt with an *asterisk
    2012 CTS-V M6 B&B X-pipe/catback,delete pipes, 630hp Lingenfelter kit, Airaid Intake,ID850s, AUX HX , catch can, Cam, forged piston and rods, 2.38 upper, 20" Vossen CV1 Bronze.
    Stage2: 641.9rwhp @6400rpm / 591rwtq @4500rpm
    Stage1: 551.7rwhp @ 5950rpm / 536.8rwtq @5150rpm
  14. #13
    Active Member
    Join Date
    Jan 2013
    Location
    Long Island, NY
    Posts
    12,263
    i change the oil in my v once a year, I typically put right around 3k miles annually
  15. #14
    Dat ass
    Join Date
    Jun 2013
    Location
    Louisville, KY
    Posts
    1,667
    Yeah I change mine once a year, usually around 2k miles on mine
    STE\/E likes this.
  16. #15
    Active Member
    Join Date
    Nov 2016
    Location
    Mid Mi
    Posts
    1,815
    Same here, I was a little early on the oil & filter change but I was going to the track so figured I'd do it now. Plans have changed for going to the track but I' won't have to change the oil & filter until next year now. May still get to the track on my own later this year yet weather permitting.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Back to top
