V2 Goodridge SS Brake line install Question
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Fasst04Caddy
Thread: V2 Goodridge SS Brake line install Question
  1. #1
    Registered User
    Join Date
    Mar 2015
    Location
    Buford, Georgia
    Posts
    8
    Has anyone on here installed Goodridge SS brake lines on their V2? I installed the Rear lines successfully on my 2012 M6 Seda, but I am having trouble figuring out which way the front lines go in. The bracket on the brake line that attaches at the Shock bolt to lower control arm is giving me fits. Which way does it go? I really dont want to do this this twice. Any help or pictures appreciated.
    2012 CTS-V Sedan 6-Speed Manual
    2004 CTS-V - For Sale
  2. #2
    Active Member
    Join Date
    Jan 2017
    Location
    Greensboro NC
    Posts
    2,727
    Quote Originally Posted by Fasst04Caddy View Post
    I don’t have a pic of that side of the control arm...might a help in an hour
    Build Thread for the Madallac
    Open and Shut - A Tranny Story (TR6060 Teardown and Rebuild)
    JRi Coilovers
    ’09 Sedan Black on Black Recaros 6MT
    Forged HED LSA 10:1 GP 2.5 Ported LSA Heads/TVS1900 Johnson 2110s 2.70/9.55 Pulleys D3 Intake Lid Spacer SW 2”/Catless/Magnaflow Resonators/Corsa Spt DIY Flex Setup ID1300Xs DW300Cs + Walbro 297 Map Ref Aux
    Low Mount D3 HX and Pump -10 Setrab Oil Cooler Diff Cooler Lowered on JRIs Subframe Reinforcement Front and Rear D3 Sway Bars Core Shifter Mantic Twin Disc Clutch Swapped/Widened Sedan Wheels
  3. #3
    Registered User
    Join Date
    Mar 2015
    Location
    Buford, Georgia
    Posts
    8
    Quote Originally Posted by adam112 View Post
    That would be excellent. Ideally a Picture of the bracket and back of caliper to see angle of line where its attached to caliper. Much appreciated. I'm holding off until I know which way it goes.
    Thanks again.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Dec 2018
    Location
    Raleigh, NC
    Posts
    249
    I'd be interested to see pics too. I installed my fronts in Feb and not sure it's in the right position either. The line is just dangling now since I couldn't figure out the bracket. Yikes! No real stresses on it but should be secured. Road Atlanta in a few weeks too.
    2011 Sedan A6 - Raven Black - Recaros- Bought it stock and quickly got addicted. and it keeps going...
    STAGE 1 - Griptec 2.38", 850 injectors, Airaid intake, Moroso catch can, Track attack HX, Varimax pump,
    - Manifolds, B&B down pipes, no cats, 22" resonators, stock mufflers (QTP cut-outs connected to Homelink)...open most the time...just too fun!
    - RPM Motorsports tune (Raleigh/Garner) - 575 whp/ 598 Tq (Dry 50 degree day)
    STAGE 2 - Mamo LS7 TB, DIY Ported snout/blower, ZL1 lid, Flex fuel sys with Aux pump & filter, ID1050's, Green filter - 650 whp/630 Tq (60 degree day)
    Forgestar 20" CF10's 9" front /11" rear with 305 Pilot Sport AS4's (flush) - Eibach coupe sport springs
    * WeaponX/ JB's -Sway bars and Diff Cooler * 18x9.5" TSW Nurburgrings and Nitto NT-01 for track days and C5 Vette 18" Replicas w/305/35/18 MT Street SS Drag Radials
    Best time of 10.75 @126 1.53 60ft and 6.91 in the 1/8th
  6. #5
    Active Member
    Join Date
    Jan 2017
    Location
    Greensboro NC
    Posts
    2,727
    Forgot Entirely once my daughter went to bed...
    I’m not sure what SS lines i have or brackets for that matter. I’ll see what I can see this afternoon.
    JRi Coilovers
  7. #6
    Registered User
    Join Date
    Mar 2015
    Location
    Buford, Georgia
    Posts
    8
    I figured it out after test fitting the lines to full lock. Here are pics what it should look like between caliper and bracket. I did eventually hook up other end of line
    Attached Thumbnails Attached Thumbnails V2 Goodridge SS Brake line install Question-0ec60979-3125-4103-90f2-327ab95a3cc2_1557625266302.jpg   V2 Goodridge SS Brake line install Question-33e76171-345c-4da3-9e76-f65103163966_1557625313572.jpg   V2 Goodridge SS Brake line install Question-362a68a4-2f14-4791-bd3f-f06dd61a215b_1557625345091.jpg
    random84 likes this.
  8. #7
    Registered User
    Join Date
    Jun 2018
    Location
    Altoona, PA
    Posts
    44
    the 2 adaptors that come in the kit, where do they go?
    Kooks 3" Headers
    Kooks X pipe
    Muffler delete
    LPE 160 Thermo
    LPE Solid Isolator
    LPE 10 Bolt Hub
    LPE 2.38 Upper
    Gates HD Green Belt
    FIC 850s
    NGK TR7ix Plugs
    Taylor 409 10.4mm Pro Wires
    Weapon X dual catch can
    Waepon X CF Side Vents
    BMR Underhood Box
    LPE Varimax pump
    Air Raid CAI Green Filter
    Ported Snout
    Ported Lid
    Ported Throttle Body
    CAGS Eliminator
    Eibach Pro springs
    LPE LNC-2001
    LPE CTAP-001
    Nitrous Outlet 90mm Plate
    200 Shot of GO-GO Juice
    Black Moon Splitter & Side Skirts
    Forgestar D5 17x11 Beadlocks rears
    Forgestar D5 18x5 fronts
    M&H 325/45R17 DRs
    M&H 185/50R18 Skinnies
    Vadder Dual Core HX
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 17
    Last Post: 05-29-2015, 10:01 PM
  2. Goodridge Stainless Steel Brake Line Installation
    By DrSpeed in forum Suspension
    Last Post: 02-22-2015, 11:04 PM
  3. V2 Goodridge brake lines
    By Octopiston in forum Brakes
    Last Post: 07-01-2014, 06:27 PM
  4. Replies: 2
    Last Post: 09-12-2013, 01:37 PM
  5. Goodridge stainless brake line kit
    By Heavymetals in forum Brakes
    Last Post: 05-10-2012, 06:04 PM
Back to top
