New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS
Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By Dedicated-Matt
  • 1 Post By Dedicated-Matt
Thread: New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS
  1. #1
    Join Date
    Mar 2017
    Posts
    16
    Cool New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS
    The Dedicated Motorsports crew has been pushing the LSA 1.9L to its absolute limit. This means small upper pulleys and a lot of belt load as we pack the blower full of air. The result is some belt slip no matter how new the Griptec pulley or how much belt tension we apply. Now that we've established the issue lets talk about the solution. First off we developed an idler relocation bracket that moves the upper idler 5mm closer to the supercharger pulley. This bracket works with all idler pulleys and also makes more room for the 9.17" and larger lower pulleys. This product is designed for the max effort guys or anyone looking to get the most out of their LSA supercharger system.
    We call this the DMS +5mm Relo Bracket. Which can be purchased here: https://www.dedicatedmotorsports.com...-p/5mmrelo.htm
    But we didn't stop there. We wanted more belt wrap so we designed a 110mm upper idler pulley. This pulley will push the belt another 5mm closer to the upper pulley for a total of 10mm additional belt height and wrap on the upper pulley. Keep in mind this pulley can only be used with the DMS idler relo bracket or a stock idler bracket. It can be purchased here. https://www.dedicatedmotorsports.com...ct-p/110mm.htm
    We also have a combo deal with the two components here: https://www.dedicatedmotorsports.com...p/-10combo.htm
    Matt
    Attached Thumbnails Attached Thumbnails New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS-idlers.jpg   New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS-idler-comparison.jpg   New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS-relo-1.jpg
  2. #2
    Active Member
    Join Date
    Mar 2017
    Location
    Huntsville, AL
    Posts
    71
    How much does the relocation bracket change the belt size? I have a 2.35 upper with plenty of belt slip so this interest me.
    13 Coupe M6
    2.35 Griptech, ID 1050X injectors, DSX Aux fuel and E85 kit, C&R Hx, Airaid intake
  3. #3
    Join Date
    Mar 2017
    Posts
    16
    Quote Originally Posted by kylew View Post
    That depends a lot on how tight the current belt is. If the belt is really loose the pulley relo combo will tighten the belt from full loose to full tight. If the current belt is tight you will need to step up one size. We will have a full belt list posted here soon.
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Mar 2017
    Location
    Huntsville, AL
    Posts
    71
    Perfect, thank you!
    13 Coupe M6
  6. #5
    Join Date
    Mar 2017
    Posts
    16
    We are currently working on a full spectrum belt guide that will be available to the public. This will include just about every upper and lower combination, including the standard relo and 100mm idler.
    Attached Thumbnails Attached Thumbnails New +5mm Idler relocation bracket and 110mm idler pulley for max belt wrap. Now in stock at DMS-img_6891-1-.jpg
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Back to top
