Billet ZL1 lid water manifolds now available!
Results 1 to 19 of 19
Like Tree9Likes
  • 2 Post By DSteck
  • 1 Post By DSteck
  • 1 Post By cav454
  • 2 Post By Lt1z
  • 1 Post By Blades1_99
  • 2 Post By Sbchris
Thread: Billet ZL1 lid water manifolds now available!
  1. #1
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    These water manifolds are intended for the LSA ZL1 lid to replace the factory piece. They feature 12ORB inlet/outlet connections and are machined from a solid piece of 6061, then they are anodized black for protection and aesthetics. These are a true 0.610" diameter all the way through in an almost straight shot to provide a little bump in flow capacity over the factory rough cast internal finish.
    The price is $200 and they are available with 12AN to 12ORB adapters for an extra $24.
    https://dsxtuning.com/collections/su...21470888198224
    Lt1z and tabio42 like this.
    DSX Tuning - St. Louis, MO
    314-396-7333
    http://www.dsxtuning.com
    http://www.facebook.com/dsx.tuning
  2. #2
    Active Member
    Join Date
    Feb 2015
    Location
    OKC, OK
    Posts
    506
    How does the height of these compare to the machined lids to clear the stock CTS-V hood?
  3. #3
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    These work with machined lids.
    314-396-7333
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Feb 2019
    Location
    Pittsburgh, PA
    Posts
    110
    looks nice, but what is exactly is being gained (besides "lil bump"). is there flow tests. Reynolds numbers, pressure tests; force/flow analysis. can you show the CFD data?
  6. #5
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    We didn’t do CFD or measure flow. These were designed and manufactured specifically to be less labor and consequently lower price for allowing the use of AN fittings on the water line connections instead of the factory push on barbs.
    Karch likes this.
    314-396-7333
  7. #6
    Active Member
    Join Date
    Feb 2015
    Location
    OKC, OK
    Posts
    506
    For sure! Itís on my list for the cooling system overhaul.
  8. #7
    Active Member
    Join Date
    Jan 2016
    Posts
    1,163
    Improvement or not. They look the goods and thatís all the really matters
    Karch likes this.
  9. #8
    Join Date
    Jul 2011
    Posts
    12,755
    Looks like a good solution to me.
  10. #9
    Active Member
    Join Date
    Aug 2017
    Location
    St. Petersburg, Fl
    Posts
    666
    So if I was planning to send my ZL1 brick out and be reinforced with A/N fittings....then this would be used instead?
    Karch likes this.
    "Pearl" is a 2011, V Coupe, A6, Recaros, Skyview.
    Mods: Airaid - Red filter, Side Swipe, Mamo LS7 Ported TB, ZL1 lid, Fasterproms underhood tank, BMR Catch Can, ....
  11. #10
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    Quote Originally Posted by Blades1_99 View Post
    Dedicated Motorsports is now using these instead of modifying existing stock pieces. It eliminates cutting and welding the stock manifold.
    314-396-7333
  12. #11
    Active Member
    Join Date
    Jan 2017
    Location
    USA
    Posts
    140
    Just a heads up and YMMV,
    Iím running this combo in the 16an setup, and the fittings do not clear the OEM hoodóI had to massage the factory fuel line union to clear my full flow 90s which left them a bit clocked up. The clocking problem could very well be my hood closing issue.
    I donít really care about the OEM hood fitment issues because I have an upgraded hood that has been sitting in a box for the past year that will easily clear the interference issues. In other words, motivation to install said hood, lol!
    (Iím running a set of Aeroflow fittings so your mileage may vary.)
    Dave,
    Please tell me this setup should clear the stock hood and Iíll go clearance the fuel elbow issues a bit more.
    2011 CTS-V Stock-ish Looking
  13. #12
    Registered User
    Join Date
    Apr 2019
    Posts
    16
    I plan on ordering one with -16orb and -16an fittings in the near future.
  14. #13
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    Quote Originally Posted by Sbchris View Post
    I’m running this combo in the 16an setup, and the fittings do not clear the OEM hood—I had to massage the factory fuel line union to clear my full flow 90s which left them a bit clocked up. The clocking problem could very well be my hood closing issue.
    I don’t really care about the OEM hood fitment issues because I have an upgraded hood that has been sitting in a box for the past year that will easily clear the interference issues. In other words, motivation to install said hood, lol!
    (I’m running a set of Aeroflow fittings so your mileage may vary.)
    Dave,
    Please tell me this setup should clear the stock hood and I’ll go clearance the fuel elbow issues a bit more.
    To be honest, I didn’t design these with full flow 16 in mind. Frankly, I am amazed two 16AN hose ends can even thread on without hitting each other. DMS tested these with 12AN to my knowledge and reported no fitment concerns.
    314-396-7333
  15. #14
    Active Member
    Join Date
    Jan 2017
    Location
    USA
    Posts
    140
    The 16an fittings do interfere with each other (have not tested other brands) but you can technically force them to work if youíre creative.
    This setup is a work of art compared to the OEM unit.
    12an vs 16an full flow comparison
    adam112 and JAustin like this.
  16. #15
    Registered User
    Join Date
    Apr 2019
    Posts
    16
    I was under the impression that this thing was gonna be the for sure way to run 1 inch line for the whole car just about.
  17. #16
    Active Member
    Join Date
    Apr 2013
    Location
    Calgary AB
    Posts
    5,582
    I got mine today but haven't installed them, looks incredible but im shocked you can get -16 fittings on them haha. (after looking at that it appears the only way to do that would be to install the ORB fitting into the lid and the elbow fitting at the same time and making sure they both are tight at the same time as the elbow fitting it self wont rotate with the other fitting in place.)
    Look to get mine mounted tomorrow
    I didnt get the nice thumb screws seen above to mount the billet unit on the lid, but im not sure if people are sourcing their own screws for that or not.
    Forged short block - Wcch heads -Jokers Chaos ported blower - gp tuning 2.5 cam and goodies - ARH Headers - 2.45/9.17 - DSX Aux fuel system - DSM filter - MM CC - PatG tuned.
    Best 1/4 mile 1.55 60f [email protected] Has more in it
  18. #17
    Join Date
    Aug 2011
    Location
    St. Louis, MO
    Posts
    4,001
    I don’t include new fasteners.
    I would imagine the 16AN lines would fit better if one ran to the driver side and one to the passenger side. I can make 12ORB to 16AN fittings with a hex that will allow them to thread in without interference, but it doesn’t solve the hose end side of things. Spacing them further apart on the manifold itself wasn’t possible due to minimum wall thickness concerns.
    314-396-7333
  19. #18
    Active Member
    Join Date
    Oct 2011
    Location
    OC, CA
    Posts
    3,208
    Nice. I had the DMS manifold on my V lid and it was a very nice piece.
  20. #19
    Active Member
    Join Date
    Jan 2016
    Posts
    1,163
    Letís be honest the difference between -12 to -16 would be marginal at best.
    Is it worth the headache and extra $$
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Similar Threads
  1. billet double bearing 100mm idlers now available
    By DSteck in forum DSX Tuning
    Last Post: 08-05-2018, 08:34 PM
  2. Replies: 65
    Last Post: 05-30-2014, 01:42 PM
Back to top
