A very detailed CTS-V Belt and Pulley Combo Size Guide with Part Numbers - Page 3
Page 3 of 3 FirstFirst 123
Results 61 to 76 of 76
Like Tree8Likes
Thread: A very detailed CTS-V Belt and Pulley Combo Size Guide with Part Numbers
  1. #61
    Active Member
    Join Date
    May 2013
    Location
    sebring, Fl
    Posts
    1,379
    that would also be a problem
    lol
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    2009 ctsv sedan M6
    Stage 1
    10.5 lower pulley; 100/50 mm idler pulley; borla cat back; id850; tr7ix plugs; track attack hx; air aid CAI; passport 9500ci; suede steering wheel;
    575hp/616tq @ 16psi.
    Stage 2 - ARRIVED
    Mamo ported Trick Flow heads; ceramic coated/ kooks catless headers; lt1z cam; zl1 lid/spacer; racing brakes; weaponxhood;
    7xx/7xxtq @ 14 psi. (no conclusive data, clutch slipping on dyno)
    Stage 3 - soon to come
    New clutch;
  2. #62
    Active Member
    Join Date
    Oct 2012
    Posts
    7,190
    Quote Originally Posted by kabooz321 View Post
    Attachment 29643
    stock upper/10.5 lower. 50/stock idlers woth relocating bracket. ko80718 is too big.
    A very detailed CTS-V Belt and Pulley Combo Size Guide with Part Numbers-uploadfromtaptalk1454610090577.jpg
    Needs to go from the crank around the tensioner then wrap around the upper
    2013 CTSV Wagon A6
    [email protected] 1.47 60 foot
    stg 2 lt1z cam, 10.5 lower, air raid intake, b&b test pipes, ls7 tb on 93 octane 627rwhp
    New setup:
    stg 2.5 lt1z cam 10.5 lower air raid TSP Longtubes jokerz port 660rwhp
    [email protected] 1.50 60 foot.
    2016 ATS-V M6 Tune only [email protected]
    CTSV Shirts- Sedan: https://teespring.com/ctsv-sedan-tshirt-hoody_copy_2 Wagon: https://teespring.com/wagonlongshorthoody_copy_3
    Coupe: https://teespring.com/shortlonghoodyoutline
  3. #63
    Active Member
    Join Date
    May 2013
    Location
    sebring, Fl
    Posts
    1,379
    Quote Originally Posted by justinschmidt1 View Post
    Click image for larger version.
    A very detailed CTS-V Belt and Pulley Combo Size Guide with Part Numbers-uploadfromtaptalk1454610322290.jpg
    thanks man, you were right.
    2009 ctsv sedan M6
    Stage 1
    Stage 2 - ARRIVED
    New clutch;
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #64
    Active Member
    Join Date
    Oct 2012
    Posts
    7,190
    There ya go lol
    Sent from my SM-G920V using Tapatalk
    2013 CTSV Wagon A6
    New setup:
  6. #65
    Active Member
    Join Date
    Oct 2011
    Location
    Langley, BC
    Posts
    480
    I'm running a 10" lower with a stock upper, relocation bracket and stock upper and lower with a 72 5/8" belt. The tensioner is showing right between the two marks on the bracket indicating that the belt is the right length. There looks to be about 3/8" to 1/2" of space between belts on the idlers. Is this a problem? I wanted to get away from using the 50mm idler I have because of the bearing failures I've heard of.
  7. #66
    Active Member
    Join Date
    Mar 2013
    Location
    Houston
    Posts
    563
    I know it was probably answered but I'm looking for a 2.5/9.1 green belt with the 50/100 idlers
    Sent from my LGLS991 using Tapatalk
    09 Black Diamond V 471/458 base line dyno #'s
    08 G8 Gt (modded)
    2004 Grand Prix GTP comp g
  8. #67
    Join Date
    Oct 2012
    Posts
    147
    Quote Originally Posted by 04chase View Post
    ill add mine since its not on the list
    2.4/9.1 with 50mm and 100mm idlers
    k080680
    added. thank you
  9. #68
    Join Date
    Oct 2012
    Posts
    147
    Quote Originally Posted by Kratos V View Post
    Size is going to be right in between a K080680 and K080685. The 685 is about 5/8" longer. K080680 should squeeze on.
    Kratos V likes this.
  10. #69
    Active Member
    Join Date
    Oct 2016
    Location
    FRANCE
    Posts
    78
    Hi,
    Do you think the quality of this belt is good for 2.55 / 100mm idler / stock ?
    Or BOSCH ?
    '11 Coupe M6
  11. #70
    Active Member
    Join Date
    Aug 2016
    Location
    Hendersonville, TN
    Posts
    1,003
    IMO, the Bando is a better belt. Bando is only in the business of belts and they make good quality stuff. Most cogged supercharger belts are Bando.
    Bosch is a big acquisition company. They buy any automotive business they think they can make money on. They move in their bloated operations structure and ruin the profitability of the company and they sell it off soon after. I've worked for two divisions of Bosch and watched this happen both times.
    09 TG Sedan A6, 2.45/9.17, ARH 1 7/8, LT1Z 2.5, GMPP CNC LS3, Jokerz chaos 102, NW102, Trunk tank/ EMP, C&R HX, Airaid, DSX pump and flex sensor, ID1050x’s. [email protected]
  12. #71
    Active Member
    Join Date
    Oct 2016
    Location
    FRANCE
    Posts
    78
    thanks
    '11 Coupe M6
  13. #72
    Active Member
    Join Date
    Jun 2016
    Location
    boise, id
    Posts
    374
    9.17 lower 2.38 upper with stock idlers k080670
    Number Of Ribs: 8
    Outside Circumference (In): 67-9/16 Inch
    Outside Circumference (mm): 1716mm
    Top Width (In): 1.087 Inch
    Top Width (mm): 28mm
  14. #73
    Active Member
    Join Date
    Apr 2018
    Posts
    321
    Bumping this thread since I hate to start another new one on the topic.
    I am about to add an 8.66 lower. Already have 2.45 upper and 100mm idler.
    Can anyone recommend the right size belt? Considering getting a 2.38 just for the hell of it and in that case I know the Gates K080670HD will work.
  15. #74
    Active Member
    Join Date
    Jan 2017
    Location
    Greensboro NC
    Posts
    2,716
    Quote Originally Posted by chaz17 View Post
    Likely uses the same size as the 2.38/8.66, but I figure wrong about half the time lol. Just depends on how tight the 670 is on the 2.38 whether you will need a size bigger or not
    Build Thread for the Madallac
    Open and Shut - A Tranny Story (TR6060 Teardown and Rebuild)
    JRi Coilovers
    ’09 Sedan Black on Black Recaros 6MT
    Forged HED LSA 10:1 GP 2.5 Ported LSA Heads/TVS1900 Johnson 2110s 2.70/9.55 Pulleys D3 Intake Lid Spacer SW 2”/Catless/Magnaflow Resonators/Corsa Spt DIY Flex Setup ID1300Xs DW300Cs + Walbro 297 Map Ref Aux
    Low Mount D3 HX and Pump -10 Setrab Oil Cooler Diff Cooler Lowered on JRIs Subframe Reinforcement Front and Rear D3 Sway Bars Core Shifter Mantic Twin Disc Clutch Swapped/Widened Sedan Wheels
  16. #75
    Active Member
    Join Date
    Sep 2017
    Location
    Baytown, TX
    Posts
    598
    Hi Chaz, just want to make sure I understood you correctly. Are you saying K080670HD is the correct belt for a 2.38 upper and 8.6 lower? Thanks.
    2012 Black CTS-V Coupe A6 (Aka: The Black Behemoth)
    Stage 1 Mods:
    Airaid CAI w\Sideswipe
    Kook 2" headers, Kooks 3" off road x-pipe, Corsa Sport mufflers
    C&R HX, BMR Reservoir, ZL1 Lid, Varimax pump, 160 T-stat
    493 HP & TQ w/93 Octane on Mustang MD250 Dyno
    Stage 2 Mods:
    Fore Fuel Pump setup w/ID 1300 Injectors and Flex Fuel Sensor
    2.38 Pulley w/Green belt & Green Air Filter
    NGK TR7IX plugs and Mighty Mouse catch can
    554 HP/570 TQ on 93 Octane - 616 HP/633 TQ w/E85 on Mustang MD250 Dyno
    Stage 3 Mods:
    Boost Mode Racing fully ported stock blower with bolt delete and 102mm snout
    Nick Williams 102 TB and Dynospeed 4.5" CAI
    630 HP/680 TQ on E85
  17. #76
    Active Member
    Join Date
    Apr 2018
    Posts
    321
    Quote Originally Posted by Force_Recon View Post
    According to the link in the OP, with the 100mm idler yes that's the belt for 2.38/8.6. Not according to me; I have not run that combo yet.
    Force_Recon likes this.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
Search tags for this page
cts v pulley chart
cts v pulley combo
cts v pulley combos
cts-v belt sizes
cts-v pulley
cts-v stock pulley size
ctsv pulley combo
ctsv pulley combos
ctsv stock pulley size
lsa belt lengeth guide
lsa pulley chart
lsa stock pulley size
Back to top
