0302 cylinder 2 misfire
Results 1 to 10 of 10
Like Tree4Likes
  • 1 Post By helloWorld
  • 1 Post By Evil_V
  • 1 Post By Jac09g8gt
  • 1 Post By Hodge
Thread: 0302 cylinder 2 misfire
  1. #1
    Active Member
    Join Date
    Jun 2013
    Posts
    78
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    I call BS (Received)
    0
    My wife's 09 ctsv continues to throw a 0302 misfire cylinder 2 misfire code when using remote start. I pulled and replaced all spark plugs. #2 was fowled compared to the others. New plug wires and moved the original #2 ignition coil to another location. With all of that it will shut off remote start with a check engine light. I can sit in it at idle with it turned on and no codes. Driving is just like normal. 90,000 miles on it and mostly stock. It sees a lot of highway miles. Any ideas or recommendations would be appreciated.
    It's been doing it on cold days only so far. I'm wondering if something is kicking on and pulling some current away. Maybe new battery time??? I emptied the catch can just in case it was full but nothing there. I was thinking something could've been coming in through the intake. I have put in some sea foam lately. Maybe it's not liking it under remote start.
    Thanks.
  2. #2
    Active Member
    Join Date
    Jun 2013
    Posts
    78
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    The engine light came back on this morning under idle without remote start. Still nothing noticeable while driving. I did clean the airrade filter and reapply oil to it a few weeks ago. I am going to pull the sensors on the intake and clean them just in case of oil coating.
    09 CTSV Auto Sedan Thunder Grey
    - Airrade Intake
    - Rosen Headrest TV's
    - Performance Spare Tire Kit
    - Backup Camera in the rearview mirror
    09 G8 GT
    - Roto Fab CAI
    - Doug Thorley LT's & Mid Muffler Delete with Xpipe
    - Cam and DOD Delete
    - Dynotuned by Mad Tunes Racing (409rwhp)
    - Polished camaro 20's
    07 Chrysler Aspen
  3. #3
    Active Member
    Join Date
    Apr 2016
    Location
    Lincoln, Nebraska
    Posts
    188
    Likes (Given)
    0
    Likes (Received)
    1
    I call BS (Given)
    0
    1
    It could be a bad fuel injector.
    My previous car had a misfire in cylinder three and I did all of the troubleshooting steps that could be done in the "spark" system and never once thought that maybe the spark was there and the fuel was not there. I had to change all the injectors out anyways to go E-85 and guess what, new injectors, no more misfire.
    Grandpa'scar likes this.
    2012 Cadillac CTS-V - Sedan - Crystal Red Tintcoat
    Transmission: Automatic - stock
    Induction: Airaid with Green Filter
    Electronics: DashLogic
    Weight: 4280 pounds with 7/16 tank of gas, no one inside
    Previous: 2013 Mustang GT - Automatic - Bolt Ons (N.A.) & E85 - 410 RWHP
  4. Remove Advertisements
    CTSVOwners.com
    Advertisements
  5. #4
    Active Member
    Join Date
    Jun 2013
    Posts
    78
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    Thanks for the input. The injector is my next step. It may need a cleaning.
    - Airrade Intake
    09 G8 GT
    - Roto Fab CAI
    07 Chrysler Aspen
  6. #5
    Active Member
    Join Date
    Jun 2013
    Posts
    78
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    The code disappeared for a week and now it's back after filling up the car with gas. Next step is I'm changing the injector but I'm open to any other suggestions on things to watch for. The misfire isn't noticeable, yet.
  7. #6
    2X 9 second club
    Join Date
    Jul 2011
    Location
    In the Basket of Deplorable
    Posts
    9,110
    Likes (Given)
    40
    Likes (Received)
    234
    I call BS (Given)
    14
    12
    swap the injector with another one and see if the misfire moves. if not, then do the same on the coil pack, then wire.
    Mikeyboyeee likes this.
    Silver surfer, 2016 Radiant Silver V3, 11.31@125 stock
    little red- 9.99@138 on the corn best mph 139 1/4 108.6 1/8 (sold)
    big silver - 9.63@142 on the spray (sold)
    my GM High Tech article:
    Hidden Content
    See the videos at:
    Hidden Content
  8. #7
    Active Member
    Join Date
    Jun 2013
    Posts
    78
    Likes (Given)
    0
    Likes (Received)
    2
    I call BS (Given)
    0
    0
    I put in a new injector a few days ago. So far it has not caused a SEL to come back on.
    12CoupeV likes this.
    - Airrade Intake
    09 G8 GT
    - Roto Fab CAI
    07 Chrysler Aspen
  9. #8
    Active Member
    Join Date
    Oct 2015
    Location
    Louisville, KY
    Posts
    61
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    probably injector as others have said. good luck
  10. #9
    Registered User
    Join Date
    Feb 2017
    Posts
    4
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    When mine misfired, the problem was about the spark, so I replaced all of them and had no problem since.
  11. #10
    Registered User
    Join Date
    Feb 2015
    Location
    Virginia
    Posts
    11
    Likes (Given)
    0
    Likes (Received)
    0
    I call BS (Given)
    0
    0
    Hoped this fixed it. I had a similar problem on my friends in cylinder #1, believe it or not, it was an intermittent connection in the Coil pack harness.
    I would assure you, this is VERY Rare..... normally as others have said, either unplug injectors remove plugs and test spark... or do the swap. I prefer to see the sparks but it is important to unplug the injectors and/or fuel pump so you are not spraying gas thru your cats or worse out the hole to ignite.
    Then just hold plug on the head while someone cranks the engine over, switch wires, switch coil packs switch plugs to eliminate spark as a variable.
    Hope you have it fixed!
    Aspiring to be V'd!
    SS Camaro was too small.
Sponsored Links
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Thread Information
Users Browsing this Thread
